KillerBot
Advice with our Patch Management
Let me preface this with I am sorry if this has been asked previously.  I've tried searching for solutions but phrasing the question in Google is difficult and I keep picking up stuff that doesn't actually address the question.
On to the actual question; we are implementing a brand new install of SCCM (the system we inherited is appalling) and everything is going great so far.  I've completely redesigned the patch management using various best practices and what works for us.  For now I've created a monthly patches SUG and a baseline SUG (that contains all updates that have not been superseded or expired).  This is based on an ADR I run manually each month and our first monthly patch went great so I moved the updates from that update group into the baseline and deleted the update group (as it was 100% compliant).  What then happened was all the updates I'd added redownloaded to the source location of the baseline (but they also stayed in the same location for the ADR created monthly deployment).
Do I now need to delete the ADR created deployment too, would that then remove the content from the duplicate location and just keep it in the baseline source folder or should I just delete it manually?
