harchihalahala1 Posted January 4, 2010 Report post Posted January 4, 2010 (edited) hi everybody i'd insalled sccm 2007 sp2 and going to build and then capture windows 7 so i made a task seqeunce wich made of 2 parts,the first part is build and the second part is...capture it then i boot client with pxe,client boots and TS install windows 7 but just the first part is ok """"""""""""""""""""""""and nothing happen at capture"""""""" windows boots with welcome screen tnx Edited January 4, 2010 by anyweb for clarity... Quote Share this post Link to post Share on other sites More sharing options...
0 anyweb Posted January 4, 2010 Report post Posted January 4, 2010 try this Capture Windows 7 task sequence instead cheers niall Quote Share this post Link to post Share on other sites More sharing options...
hi everybody
tnx
Edited by anywebfor clarity...
