  On 7/26/2017 at 5:04 PM, xerxes2985 said:
I am attempting to image a VM by PXE through VSphere. I can successfully PXE boot, but during the "loading files: boot.sdi" it is extremely slow. Then when it attempts to load the WIM, it just sits there.
Any thoughts?
Expand
OK, so this is still an issue. The network adapter for the Virtual Machine is Intel E1000e, Looking at SMSPXE.log, it takes about 15 minutes to load up "boot.sdi". Once that finally loads, now it just sits attempting to load the .wim.
Inside that log I see the following messages stating Looking for bootimage LIB00017
Getting boot action for unknown machine: item key: 2046820352	SMSPXE	1/31/2018 11:31:24 AM	4396 (0x112C)
Prioritizing local MP http://hidingthename.	SMSPXE	1/31/2018 11:31:24 AM	4396 (0x112C)
Request using architecture 0.	SMSPXE	1/31/2018 11:31:24 AM	4396 (0x112C)
Client boot action reply: <ClientIDReply><Identification Unknown="0" DuplicateSMBIOS="0" DuplicateMACAddress="0" ItemKey="2046820352" ServerName=""><Machine><ClientID/><NetbiosName/></Machine></Identification><PXEBootAction LastPXEAdvertisementID="" LastPXEAdvertisementTime="" OfferID="" OfferIDTime="" PkgID="" PackageVersion="" PackagePath="" BootImageID="" Mandatory=""/></ClientIDReply>
	SMSPXE	1/31/2018 11:31:25 AM	4396 (0x112C)
Request retry.	SMSPXE	1/31/2018 11:31:25 AM	4396 (0x112C)
Client boot action reply: <ClientIDReply><Identification Unknown="0" DuplicateSMBIOS="0" DuplicateMACAddress="0" ItemKey="2046820352" ServerName=""><Machine><ClientID>e4306477-31e7-4e98-ae8b-5c8c0fa02d63</ClientID><NetbiosName/></Machine></Identification><PXEBootAction LastPXEAdvertisementID="" LastPXEAdvertisementTime="" OfferID="LIB200A7" OfferIDTime="1/11/2018 2:08:00 PM" PkgID="LIB000F8" PackageVersion="" PackagePath="http://hidingthename/SMS_DP_SMSPKG$/LIB00017" BootImageID="LIB00017" Mandatory="0"/></ClientIDReply>
00:0C:29:F3:2A:C6, 44B74D56-8008-0282-C560-91A380F32AC6: found optional advertisement LIB200A7	SMSPXE	1/31/2018 11:31:25 AM	4396 (0x112C)
Getting boot action for unknown machine: item key: 2046820353	SMSPXE	1/31/2018 11:31:27 AM	4396 (0x112C)
Prioritizing local MP http://hidingthename.	SMSPXE	1/31/2018 11:31:27 AM	4396 (0x112C)
Request using architecture 9.	SMSPXE	1/31/2018 11:31:27 AM	4396 (0x112C)
Client boot action reply: <ClientIDReply><Identification Unknown="0" DuplicateSMBIOS="0" DuplicateMACAddress="0" ItemKey="2046820353" ServerName=""><Machine><ClientID>068f4962-b83f-480d-a450-dc75c1a13cf3</ClientID><NetbiosName/></Machine></Identification><PXEBootAction LastPXEAdvertisementID="" LastPXEAdvertisementTime="" OfferID="LIB200A7" OfferIDTime="1/11/2018 2:08:00 PM" PkgID="LIB000F8" PackageVersion="" PackagePath="http://hidingthename/SMS_DP_SMSPKG$/LIB00017" BootImageID="LIB00017" Mandatory="0"/></ClientIDReply>
00:0C:29:F3:2A:C6, 44B74D56-8008-0282-C560-91A380F32AC6: found optional advertisement LIB200A7	SMSPXE	1/31/2018 11:31:27 AM	4396 (0x112C)
Looking for bootImage LIB00017	SMSPXE	1/31/2018 11:31:27 AM	4396 (0x112C)
Report Body: <ReportBody><ClientID>068f4962-b83f-480d-a450-dc75c1a13cf3</ClientID><StateMessage MessageTime="20180131173127.000000+000" SerialNumber="1"><ClientID>068f4962-b83f-480d-a450-dc75c1a13cf3</ClientID><Topic ID="PXE Boot Client" Type="601" IDType="601"/><State ID="100" Criticality="0"/><UserParameters Flags="32" Count="4"><Param>00:0C:29:F3:2A:C6</Param><Param>44B74D56-8008-0282-C560-91A380F32AC6</Param><Param>131.204.174.92</Param><Param>LIB</Param></UserParameters></StateMessage></ReportBody>
Now, it is just sitting on loading files, and not moving. Any suggestions? What logs show the status of the .wim loading? Please help.
Any ideas???
The boot.sdi loads. Then the .WIM loads, and immediately after the bar gets to the end, the screenshot above occurs.
I have loaded ALL of the VMWare Tools drivers into SCCM. I have updated the boot image to utilize the network drivers and storage drivers.
Here is the hardware configuration:
ESXi 5.5
VMNet3 Adapter
Found a solution to the issue:
From the website here: Apparently, the limitation is only applicable to VMWare ESXi. And in my testing, specifically 5.x. Once changing the value to 1432, and using EFI, imaging is working fine.
http://www.bctechnet.com/vmware-pxe-limitations/
  Quote
This basically means that VMware cannot support RamDiskTFTPBlockSize being any bigger than 1432.  This is a pretty big limitation since this affects our ability to reasonably support our physical machines and VMware machines at the same time.  It also seems bad since VMware is the only vendor I can find that has this problem.  It wouldn’t be a huge problem if at least supported 8192, but not even 2048 works.
Expand
The only thing that is still ridiculously slow, is even attempting this using BIOS.
Hope this helps someone who may come across this.
thanks for posting the solution ! i'm also seeing really slow network boot on some vmware workstation labs I have... it would be great to increase that speed somehow
Expand
You're welcome. What is interesting is that on an ESXi running 6.0 (haven't tried 6.5 yet) it was able to PXE and successfully image using the RamDiskTFTPBlockSize=16384. However the only part that was slow was trying to load boot.sdi.
