hooligan88 Posted July 28, 2017 Report post Posted July 28, 2017 Hi Experts, Looking for some help to understand a rather tricky topic. This has been my understanding so far: Core-based licensing System Center 2016 Standard and Datacenter Server MLs are Core-based licenses. A Server ML Core license must be assigned to each physical core in the server, with a minimum of 8 Core licenses per processor, and a minimum of 16 Core licenses per server. Used Case 1: a single processor server with 4 cores requires 16 Server ML Core licenses, and a 4 processor server with 8 cores on each processor requires 32 Server ML Core licenses. Server ML Core licenses are purchased in 2-packs from resellers and always include Software Assurance. Licensing Rules Software Assurance is included with all Client MLs .When purchased outside of the CAL Suites, Client MLs are available on a Per OSE or Per User basis When purchased via the CAL Suites, Client MLs are available on a Per Device or Per User basis Client MLs include the right to run the Management Server software and SQL Server. Virtualization Rights System Center 2016 Datacenter • The server must be fully licensed with Server ML Core licenses • An unlimited number of virtual machines may be managed on the server System Center 2016 Standard • The server must be fully licensed with Server ML Core licenses • 2 virtual machines may be managed on the server The server must be licensed again to manage a further 2 virtual machines. Used Case 2: A single processor server with 8 cores requires 16 Server ML Core licenses to manage 2 VMs. A further 16 Server ML Core licenses must be assigned to the server to manage another 2 VMs. Another statement in the whitepapers say A customer is eligible for License Mobility through Software Assurance that allows • System Center Standard 2016: rights to manage 2 VMs per licensed server • System Center Datacenter 2016 rights to manage 10 VMs per licensed server Could someone help understand, how would the license calculation work for an ESX on which 200+ VMs are hosted. Would we be licensing only the cores on the ESX box or the VMs hosted as per the matrix given above? Sorry, if this being repeated but I wasn't able to get a clear explanation which will help us calculate the ML licenses.We will get in touch withour licensing partner but need to project an approximate count with at least 10% growth to get a budget forecast. Quote Share this post Link to post Share on other sites More sharing options...
hooligan88 Posted August 5, 2017 Report post Posted August 5, 2017 Any input to this will be much appreciated. Quote Share this post Link to post Share on other sites More sharing options...
