mcamero Posted August 7, 2017 Report post Posted August 7, 2017 Hello, So it seems that this is a fairly common issue with Windows 10 1703 Creator's Update. When applying an image via task sequence, the task sequence progress window is hidden behind "Just a Moment..." screen. The image completes successfully but it just seems as if it is not progressing during this "Just a Moment..." screen. My Co-Worker found this thread and we have been attempting to apply the answer file but without success. https://amp.reddit.com/r/SCCM/comments/641te0/osd_progress_hidden_behind_a_just_a_moment_screen/diytpfa/ I also created my own answer file using WSIM. I've been using these 2 threads for capturing my WIM and applying the answer file. https://www.windows-noob.com/forums/topic/5070-how-can-i-capture-an-image-using-capture-media-in-configmgr-2012/ (Thank you AnyWeb!!) https://jacobsalmela.com/2016/03/30/how-to-image-a-computer-with-windows-10-using-dism/ What I've done so far: 1. Installed and Configured Windows on VM in Hyper-V. Copied VM (exported/imported) for use later as golden WIM. 2. Captured WIM using AnyWeb's walkthrough linked above. 3. I used this newly captured WIM in WSIM to create my answer file. 4. I then copied the unattend.xml to the original VM created in step 1 above. I copied to the location c:\Windows\System32\Sysprep 5. I ran the command from an elevated cmd prompt: sysprep.exe /generalize /oobe /unattend:Unattended.xml (The walkthrough linked above from jaobsalmela states to add /shutdown at the end of that command but I did not add that hoping that I would be able to run the capturemedia.iso created from ConfigMgr after this step. Unfortunately this step even without the /shutdown switch did in fact shut the VM down.) 6. I started the VM again and of course it went through the OOBE (The answer file worked because I was not prompted for any input, but it did the configuration). So now I tried to run the capturemedia.iso created in ConfigMgr and one of the first things it does is sysprep, which failed of course. This is where I am stuck. So I am trying to apply the unnattend.xml before I capture the WIM, how would I go about this? Maybe I'm doing the entire process wrong. I'm still fairly new at this, if I followed jacobsalmela post further, to me it looks as if it creates two different WIM files for two different partitions. I would not know what to do with these in the ConfigMgr task sequence. Thank you! Quote Share this post Link to post Share on other sites More sharing options...
