In my experience I keep the base wim pretty much vanilla and then use the build task sequence to add agents, third-party apps etc.
in case of Windows 7 I pretty much only included IE 9 slip streamed into the wim initially and with Windows 10 I just removed built in apps from the wim file.
I guess it depends on your environment if a thin image or a fat image suites but using a thin images allows the update of third-party apps easier.
