  On 8/18/2017 at 6:18 PM, gavin1973 said:
Just to clarify the laptop is able to pxe boot and pull down your boot image but fails before the task sequence starts?
Expand
Yes. I am using a surface Ethernet adapter model 1821 (Gigabit Ethernet USB 3.0).
it fails when it's trying to prepare network connections.
I have a surface Ethernet adapter model 1663 (gigabit Ethernet USB 3.0) and it allows me to get through the whole process.
It very much sounds like nic drivers needed in the boot image which has caused me headaches over the years and have you added the driver pack into SCCM task sequence?
in past experience boot image has been fine but not having the correct drivers in the task sequence let me down.
