sccm_freak
create a DB in SQL2k8 cluster
hi there
im wondering how can i create a DB in an sql2k8 cluster , lets say i have 2 nodes and its configured succesfully for clustering and i can move the resources from one cluster to another , i want to know the DB itself how can i create or add one to that SQL cluster ? will i open the sql server management studio and specify the sql cluster name in the server name field or what ?
waiting your reply soon
thanks
3 answers to this question
  On Invalid Date at NaN:NaN PM, sccm_freak said:
hi there
thanks
just use the cluster resource name to login. If you hit the browse button it should search the LAN for all db servers and select from the list :-)
then once it's logged in, on the left tree menu right-click databases select create :-)
note this is from memory, will confirm on 08 cluster in about 8 hours :-)
