xeronine
Remote Control failure
Hi All,
In SCCM 1706 we are having issues using the Remote Control tools. When you launch Remote Control, the window hangs on "Connecting to the host session".
here is a screenshot of the applied remote tools client settings:
Note: The "set Viewers" includes 3 security groups for the teams responsible for remote support (including the user where logs were generated from).
CmRcService.log (user system log):
Quote
======> A connection has been established. (OnConnectionEstablished)    CmRcService    9/25/2017 7:16:46 PM    4920 (0x1338)
Ready to start the security handshake.    CmRcService    9/25/2017 7:16:46 PM    4920 (0x1338)
=== Starting security handshake ===    CmRcService    9/25/2017 7:16:46 PM    4920 (0x1338)
=== Security handshake completed [0x10000000] ===    CmRcService    9/25/2017 7:16:46 PM    4920 (0x1338)
The viewer is a member of the Local Administrators group who are allowed to use Remote control.    CmRcService    9/25/2017 7:16:46 PM    4920 (0x1338)
The user(DOMAIN\username) is authorized for Remote Control    CmRcService    9/25/2017 7:16:46 PM    4920 (0x1338)
Session allowed: Full Control    CmRcService    9/25/2017 7:16:46 PM    4920 (0x1338)
=== Session Info ===    CmRcService    9/25/2017 7:16:46 PM    4920 (0x1338)
    Authorized viewer user: DOMAIN\username    CmRcService    9/25/2017 7:16:46 PM    4920 (0x1338)
    Viewer address: xx.xx.xx.xx:64924    CmRcService    9/25/2017 7:16:46 PM    4920 (0x1338)
    Host address: xx.xx.xx.xx:2701    CmRcService    9/25/2017 7:16:46 PM    4920 (0x1338)
The connection has been terminated (ID = 1). (OnConnectionTerminated)    CmRcService    9/25/2017 7:17:49 PM    5744 (0x1670)
WT_WSACompleteIO failed due to Network shutdown: -1073741536    CmRcService    9/25/2017 7:17:49 PM    7988 (0x1F34)
VmRcViewer.log (configman console rmeote control log):
Quote
====== Starting CMRCViewer.exe ======    CmRcViewer    9/25/2017 7:16:45 PM    13584 (0x3510)
Command line: "D:\Program Files (x86)\Microsoft Configuration Manager\AdminConsole\bin\i386\CmRcViewer.exe"  HOSTNAME \\SCCM.SERVER    CmRcViewer    9/25/2017 7:16:45 PM    13584 (0x3510)
   Remote control target: HOSTNAME    CmRcViewer    9/25/2017 7:16:45 PM    13584 (0x3510)
Initialized settings - Clipboard Sharing: True, Keyboard Translation: False, Color Depth: 32 bpp, Optmize for Low bandwidth: False     CmRcViewer    9/25/2017 7:16:45 PM    13584 (0x3510)
Windows Version 6.3.9600 is supported OS.    CmRcViewer    9/25/2017 7:16:45 PM    13584 (0x3510)
====== Starting remote control session with remote system ======> [HOSTNAME]    CmRcViewer    9/25/2017 7:16:46 PM    12464 (0x30B0)
Attempting connection to IPv4 address: xx.xx.xx.xx    CmRcViewer    9/25/2017 7:16:46 PM    12464 (0x30B0)
Successfully connected to address [xx.xx.xx.xx:2701]    CmRcViewer    9/25/2017 7:16:46 PM    12464 (0x30B0)
The remote control stream is initialized.    CmRcViewer    9/25/2017 7:16:46 PM    12464 (0x30B0)
The remote control stream is opened    CmRcViewer    9/25/2017 7:16:46 PM    12464 (0x30B0)
Security filter Stream is Initialized.    CmRcViewer    9/25/2017 7:16:46 PM    12464 (0x30B0)
=== Starting security handshake ===    CmRcViewer    9/25/2017 7:16:46 PM    12464 (0x30B0)
Security handshake is in progress...    CmRcViewer    9/25/2017 7:16:46 PM    12464 (0x30B0)
Negotiated Package name = Kerberos, Version = 1 comment = Microsoft Kerberos V1.0    CmRcViewer    9/25/2017 7:16:46 PM    12464 (0x30B0)
Trailer length =76, max Message size = 131326    CmRcViewer    9/25/2017 7:16:46 PM    12464 (0x30B0)
=== Security handshake completed [0x10000000] ===    CmRcViewer    9/25/2017 7:16:46 PM    12464 (0x30B0)
Success: Full control mode    CmRcViewer    9/25/2017 7:16:46 PM    12464 (0x30B0)
Turning off performance flags..    CmRcViewer    9/25/2017 7:16:46 PM    13584 (0x3510)
Not optimized for low bandwidth     CmRcViewer    9/25/2017 7:16:46 PM    13584 (0x3510)
Clipboard sharing is enabled. Remote control mode is Full control and Viewer clipboard sharing is enabled.    CmRcViewer    9/25/2017 7:16:46 PM    13584 (0x3510)
Cleared the clipboard for a new connection    CmRcViewer    9/25/2017 7:16:46 PM    13584 (0x3510)
SmartSize = Enabled    CmRcViewer    9/25/2017 7:16:46 PM    13584 (0x3510)
Receive completed asynchronously with zero bytes. Stream disconnected.    CmRcViewer    9/25/2017 7:17:49 PM    15108 (0x3B04)
Stream is opened    CmRcViewer    9/25/2017 7:17:49 PM    15108 (0x3B04)
Disconnecting the connection.
An existing connection was forcibly closed by the remote host. (Error: 80072746; Source: Windows)    CmRcViewer    9/25/2017 7:17:49 PM    15108 (0x3B04)
The remote control session transport stream has been closed.    CmRcViewer    9/25/2017 7:18:51 PM    23200 (0x5AA0)
Now graceful shutdown is ready for the socket closing.    CmRcViewer    9/25/2017 7:18:51 PM    23200 (0x5AA0)
Cleared the clipboard for a new connection    CmRcViewer    9/25/2017 7:18:51 PM    13584 (0x3510)
Terminating the MSTSCAX ActiveX control.    CmRcViewer    9/25/2017 7:18:51 PM    13584 (0x3510)
Any help is greatly appreciated!
Matt
