Boundaries With Sites and Services Issue
OUR SETUP
We have a SCCM 2012 server which we recently took over. Our setup consist of 13 remote sites with DP's in 6 and 32 subnets between them all.
Our sites and services setup in AD has been configured correctly and very carefully due to the complication of all the subnets of various sizes (/24 /25 /26 /27 etc..) We are'nt SCCM experts by any stretch of the imagination but know infrastructure and networking well and are confident that sites and services has been setup 100% correctly.
OUR FINDINGS
We recently had a closer look at the SCCM server to try and improve the general performance - Takes very long to come back with anything whenever you do anything in it.(assume the SQL queries are the issue)
Starting at the basics we had a look at boundaries first and found that the discovery methods are setup for site and IP address ranges.
Since our sites and services are setup correctly we thought we could get rid of the IP ranges as I have read multiple articles stating that this is a very "Expensive Query" - and therefore just use sites.
OUR PROBLEM
The minute we remove the IP range the "remote" workstations (sites with DP's)will not run the task Sequence after PXE booting
Tail end of the smsts.log file
<![LOG[  Flags: 01000000]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="1" thread="1824" file="resolvesource.cpp:2291">
<![LOG[  URLs : 1]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="1" thread="1824" file="resolvesource.cpp:2292">
<![LOG[  SMB  : ]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="1" thread="1824" file="resolvesource.cpp:2293">
<![LOG[  MCS  : ]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="1" thread="1824" file="resolvesource.cpp:2294">
<![LOG[No static content server.]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="1" thread="1824" file="resolvesource.cpp:2371">
<![LOG[(LocationsList.size() + slistHttpPaths.size() + slistSMBPaths.size()) > 0, HRESULT=80040102 (e:\nts_sccm_release\sms\framework\tscore\resolvesource.cpp,2427)]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="0" thread="1824" file="resolvesource.cpp:2427">
<![LOG[FALSE, HRESULT=80040102 (e:\nts_sccm_release\sms\framework\tscore\tspolicy.cpp,2000)]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="0" thread="1824" file="tspolicy.cpp:2000">
<![LOG[Content location request for QAT00002:3 failed. (Code 0x80040102)]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="3" thread="1824" file="tspolicy.cpp:2000">
<![LOG[hr, HRESULT=80040102 (e:\nts_sccm_release\sms\framework\tscore\tspolicy.cpp,2845)]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="0" thread="1824" file="tspolicy.cpp:2845">
<![LOG[Failed to resolve PackageID=QAT00002]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="3" thread="1824" file="tspolicy.cpp:2845">
<![LOG[(*iTSReference)->Resolve( pTSPolicyManager, dwResolveFlags ), HRESULT=80040102 (e:\nts_sccm_release\sms\framework\tscore\tspolicy.cpp,3693)]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="0" thread="1824" file="tspolicy.cpp:3693">
<![LOG[m_pSelectedTaskSequence->Resolve( m_pPolicyManager, TS::Policy::TaskSequence::ResolvePolicy | TS::Policy::TaskSequence::ResolveSource, fpCallbackProc, pv, hCancelEvent), HRESULT=80040102 (e:\nts_sccm_release\sms\client\tasksequence\tsmbootstrap\tsmediawizardcontrol.cpp,1439)]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="0" thread="1824" file="tsmediawizardcontrol.cpp:1439">
<![LOG[Failed to resolve selected task sequence dependencies. Code(0x80040102)]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="3" thread="1824" file="tsmediawizardcontrol.cpp:1439">
<![LOG[hrReturn, HRESULT=80040102 (e:\nts_sccm_release\sms\client\tasksequence\tsmbootstrap\tsmediaresolveprogresspage.cpp,445)]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="0" thread="1824" file="tsmediaresolveprogresspage.cpp:445">
<![LOG[ThreadToResolveAndExecuteTaskSequence failed. Code(0x80040102)]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="3" thread="1824" file="tsmediaresolveprogresspage.cpp:445">
<![LOG[ThreadToResolveAndExecuteTaskSequence returned code 0x80040102]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="1" thread="516" file="tsmediaresolveprogresspage.cpp:221">
<![LOG[Setting wizard error: This task sequence cannot be run because the program files for QAT00002 cannot be located on a distribution point. For more information, contact your system administrator or helpdesk operator.]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="0" thread="516" file="tsmediawizardcontrol.cpp:1463">
<![LOG[ResolveProgressPage::OnWizardNext()]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="0" thread="516" file="tsmediaresolveprogresspage.cpp:113">
<![LOG[Activating Finish Page.]LOG]!><time="11:56:30.378-600" date="11-24-2017" component="TSPxe" context="" type="0" thread="516" file="tsmediafinishpage.cpp:107">
<![LOG[Loading bitmap]LOG]!><time="11:56:30.394-600" date="11-24-2017" component="TSPxe" context="" type="1" thread="516" file="tsmbootstrap.cpp:1303">
If we add the IP Ranges back it works. I can see the problem (highlighted) and know how to get around it but don't understand why we cannot get it to use Sites and Services correctly.
We have ensured that the DP servers Boundaries and Boundary Groups are all connected
  • Boundary Discovered and Defined correctly.
  • Boundary Group has correct Boundary in it.
  • Boundary Group Reference has DP server defined as Site System Server
We have made sure that the packages have sync'd/copied correctly with the DP's and the sizes all match.
Obviously we are missing something - Can anyone provide any further advice?
And I will just say again, we have just spent two weeks documenting and going over our Sites / Subnet / AD setup to ensure we have no overlapping networks and to ensure all our subnets are defined correctly in sites and services - We really don't think the issue lies there but are open to any advice.
Thank You in advance.
  • 1 year later...
