sweety_devil
How to exclude system and user certificates with USMT
We are migrating from Windows 7 to Windows 10 1703 and we have a task sequence with USMT.
We have an issue with the old certificates which are imported during the capture and prevent the SCCM client to work correctly.
Do you know how to exclude the certificates during the capture ?
I tried to modify my custom.xml and add theses lines but it doesn't work:
<component type="Documents" context="System">
       <displayName>SkipMachineCerts</displayName>
       <role role="Data">
          <rules>
      <unconditionalExclude>
                <objectSet>
                   <pattern type="Registry">HKLM\SOFTWARE\Microsoft\SystemCertificates\My\Certificates\*[*]</pattern>
                </objectSet>
             </unconditionalExclude>
          </rules>
       </role>
    </component>
       <role role="Data">
          <rules>
                <objectSet>
                </objectSet>
          </rules>
       </role>
    </component>
Expand
The most precise way to do this is to set the "migrate" property to "no" in the following two lines of your generated Config.xml file:
<component displayname="Microsoft-Windows-Crypto-keys" migrate="no" ID="http://www.microsoft.com/migration/1.0/migxmlext/cmi/microsoft-windows-crypto-keys/microsoft-windows-crypto-keys/settings"/>
<component displayname="Microsoft-Windows-CAPI2-certs" migrate="no" ID="http://www.microsoft.com/migration/1.0/migxmlext/cmi/microsoft-windows-capi2-certs/microsoft-windows-capi2-certs/settings"/>
