I am running into issues with enabling HTTPS for my site.
All my clients are utilizing a PKI certificate, my DP is using a certificate that meets the requirements.
I first switch my MP to HTTPS, and no errors in logs on the server, however, communication between server-client doesn't work.
I checked CCMmessaging.log and these are the errors.
Raising event:
instance of CCM_CcmHttp_Status
	ClientID = "GUID:39c25844-fdcd-4128-ad02-afbbbb7da681";
	DateTime = "20180306185215.125000+000";
	HostName = "Servername-hidden";
	HRESULT = "0x87d0027e";
	ProcessID = 724;
	StatusCode = 403;
	ThreadID = 300;
	CcmMessaging	3/6/2018 12:52:15 PM	300 (0x012C)
Successfully queued RefreshSecuritySettingsEvent event.	CcmMessaging	3/6/2018 12:52:15 PM	300 (0x012C)
Successfully queued event on HTTP/HTTPS failure for server 'Servername-hidden'.	CcmMessaging	3/6/2018 12:52:15 PM	300 (0x012C)
Post to http://Servername-hidden/ccm_system_windowsauth/request failed with 0x87d00231.	CcmMessaging	3/6/2018 12:52:15 PM	300 (0x012C)
[CCMHTTP] ERROR: URL=http://Servername-hidden/ccm_system/request, Port=80, Options=480, Code=0, Text=CCM_E_BAD_HTTP_STATUS_CODE	CcmMessaging	3/6/2018 1:14:47 PM	4980 (0x1374)
Raising event:
	DateTime = "20180306191447.628000+000";
	ProcessID = 724;
	StatusCode = 503;
	ThreadID = 4980;
Successfully queued event on HTTP/HTTPS failure for server 'Servername-hidden'.	CcmMessaging	3/6/2018 1:14:47 PM	4980 (0x1374)
Post to http://Servername-hidden/ccm_system/request failed with 0x87d00231.	CcmMessaging	3/6/2018 1:14:47 PM	4980 (0x1374)
[CCMHTTP] ERROR: URL=http://Servername-hidden/ccm_system/request, Port=80, Options=480, Code=0, Text=CCM_E_BAD_HTTP_STATUS_CODE	CcmMessaging	3/6/2018 1:16:47 PM	11316 (0x2C34)
Raising event:
	DateTime = "20180306191647.300000+000";
	ProcessID = 724;
	StatusCode = 503;
	ThreadID = 11316;
Successfully queued event on HTTP/HTTPS failure for server 'Servername-hidden'.	CcmMessaging	3/6/2018 1:16:47 PM	11316 (0x2C34)
Post to http://Servername-hidden/ccm_system/request failed with 0x87d00231.	CcmMessaging	3/6/2018 1:16:47 PM	11316 (0x2C34)
So, I went ahead and switched the MP back to HTTP, and the clients still cannot communicate with the server.
Help please.
excerpt_ccmmessaging_log.log
>>> Selected Certificate [Thumbprint 9d93c668ac7b318448c5e7e97fe6dca10984b6e7] issued to 'server-name-hidden' for HTTPS Client Authentication	SMS_MP_CONTROL_MANAGER	3/6/2018 1:00:38 PM	13240 (0x33B8)
Failed to send http request /SMS_MP/.sms_aut?MPLIST. Error 12030	SMS_MP_CONTROL_MANAGER	3/6/2018 1:00:38 PM	13240 (0x33B8)
Call to HttpSendRequestSync failed for port 443 with 12030 error code.	SMS_MP_CONTROL_MANAGER	3/6/2018 1:00:38 PM	13240 (0x33B8)
Mpcontrol.log error message when switched to HTTPS
