iico
Upgrade to IE11 Issue
Hello all,
I need to upgrade IE9 on windows 7 To IE11, i did follow all steps on the following article:
https://social.technet.microsoft.com/wiki/contents/articles/28624.deploy-internet-explorer-11-using-sccm-2012-r2.aspx
I checked IE and still 9.
I checked the following:
1- application status on SCCM successe.
2- software center on client computer, and its successed (installed).
3- AppEnforce.log on client computer and there is no error.
4- Windows update service is installed on that computer, and .net 4.5.1 is installed as well.
What else can i check.
Best Regards,
i found following error on IE11_main.log on client PC:
00:00.016: Started: 2018/04/03 (Y/M/D) 08:08:10.447 (local)
00:00.031: Time Format in this log: MM:ss.mmm (minutes:seconds.milliseconds)
00:00.031: Command line: C:\Windows\Temp\IXP000.TMP\IE-REDIST.exe  /ieak-full:C:\Windows\Temp\IXP000.TMP\ /quiet
00:00.031: INFO:    Setup installer for Internet Explorer: 11.0.9600.16428
00:00.031: INFO:    Previous version of Internet Explorer: 9.0.8112.16421
00:00.031: INFO:    Setup exit code: 0x00009C4F (40015) - Wrong OS Version.
00:00.031: INFO:    Scheduling upload to IE SQM server: http://sqm.microsoft.com/sqm/ie/sqmserver.dll
00:00.063: ERROR:   SQM Upload failed while uploading "C:\Users\Default\AppData\Local\Microsoft\Windows\Temporary Internet Files\SQM\iesqmdata_setup0.sqm" with error: 2147954407
00:00.063: ERROR:   SQM Upload failed while uploading "C:\Users\Default\AppData\Local\Microsoft\Windows\Temporary Internet Files\SQM\iesqmdata_setup1.sqm" with error: 2147954407
00:00.063: ERROR:   SQM Upload failed while uploading "C:\Users\Default\AppData\Local\Microsoft\Windows\Temporary Internet Files\SQM\iesqmdata_setup2.sqm" with error: 2147954407
00:00.063: ERROR:   SQM Upload failed while uploading "C:\Users\Default\AppData\Local\Microsoft\Windows\Temporary Internet Files\SQM\iesqmdata_setup3.sqm" with error: 2147954407
00:00.063: ERROR:   SQM Upload failed while uploading "C:\Users\Default\AppData\Local\Microsoft\Windows\Temporary Internet Files\SQM\iesqmdata_setup4.sqm" with error: 2147954407
00:00.094: INFO:    Cleaning up temporary files in: C:\Windows\TEMP\IE13076.tmp
00:00.094: INFO:    Unable to remove directory C:\Windows\TEMP\IE13076.tmp, marking for deletion on reboot.
00:00.094: INFO:    Released Internet Explorer Installer Mutex
