Error information persisted in the database.        4/11/2018 3:38:14 PM   1376 (0x0560)
Waiting for changes to the "C:\Program Files\Microsoft Configuration Manager\inboxes\cmupdate.box" directories, updates will be polled in 600 seconds... 4/11/2018 3:38:14 PM   1376 (0x0560)
There is no redist version. Use default redist version 201710         4/11/2018 3:48:13 PM   1376 (0x0560)
INFO: setup type: 1, top level: 1.                4/11/2018 3:48:13 PM   1376 (0x0560)
Update package will not install as it is marked for prereq check only.        4/11/2018 3:48:13 PM   1376 (0x0560)
INFO: SQL Connection succeeded. Connection: SMS ACCESS, Type: Secure             4/11/2018 3:48:13 PM   1376 (0x0560)
Error information persisted in the database.        4/11/2018 3:48:13 PM   1376 (0x0560)
Waiting for changes to the "C:\Program Files\Microsoft Configuration Manager\inboxes\cmupdate.box" directories, updates will be polled in 600 seconds... 4/11/2018 3:48:13 PM   1376 (0x0560)
This looks like SCCM 1710.
Stuck in what process of the update? Download, installation? And stuck how?
"Update package will not install as it is marked for prereq check only" You ran a pre-requisites check all seems to pass. What does C:\ConfigMgrPrereq.log say?
Have you tried to restarting the SMS_Executive component?
