jblackburn
sccm client not running powershell script on some machines
I'm getting an error back on around 20% of clients failing to run scripts.
When my script runs that is part of an advert I get an error in execmgr.log listing error
"Invalid executable file powershell"
The exact same script is working on 80% of machines!! I am currently on Windows 10 generally build 1703 but the issue happens on build 1709 as well. If I rebuild the machine I get no issues the scripts run on the same machine. I'm trying to figure out the cause so I don't need to reimage the whole machine just because it won't run a powershell script. My sccm is on the latest 1803 and the clients are updating correctly showing the latest version
I am using the following command to execute the script
powershell -executionPolicy unrestricted -noexit -file ".\filename"
Execmgr give the following as an example.
Executing program powershell -executionPolicy unrestricted -noexit -file ".\DeleteWindowsOld.ps1" in --Admin context execmgr 18/04/2018 16:08:55 8240 (0x2030)
Execution Request for advert HWA20032 package HWA00059 program CleanMgr state change from --Ready to NotifyExecution execmgr 18/04/2018 16:08:55 8240 (0x2030)
Raising client SDK event for class CCM_Program, instance -----CCM_Program.PackageID="HWA00059",ProgramID="CleanMgr", actionType 1l, value , user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 18/04/2018 16:08:55 8240 (0x2030)
Checking content location C:\Windows\ccmcache\5 for use execmgr 18/04/2018 16:08:55 8240 (0x2030)
Successfully selected content location C:\Windows\ccmcache\5 execmgr 18/04/2018 16:08:55 8240 (0x2030)
Executing program as a script execmgr 18/04/2018 16:08:55 8240 (0x2030)
Invalid executable file powershell execmgr 18/04/2018 16:08:55 8240 (0x2030)
Raising event:
[SMS_CodePage(437), SMS_LocaleID(1033)]
instance of SoftDistProgramBadEnvironmentEvent
 AdvertisementId = "HWA20032";
 ClientID = "GUID:ADC31248-103F-4445-B66C-6E7F874719AB";
 CommandLine = "powershell -executionPolicy unrestricted -noexit -file \".\\DeleteWindowsOld.ps1\"";
 DateTime = "20180418150855.412000+000";
 DriveLetter = "";
 MachineName = "TL-1004";
 PackageName = "HWA00059";
 ProcessID = 5776;
 ProgramName = "CleanMgr";
 SiteCode = "HWA";
 ThreadID = 8240;
 Win32ErrorCode = 2147942402;
 WorkingDirectory = "";
Raised Program Bad Environment Event for Ad:HWA20032, Package:HWA00059, Program: CleanMgr execmgr 18/04/2018 16:08:55 8240 (0x2030)
EnterRsRuningState failed to run script powershell -executionPolicy unrestricted -noexit -file ".\DeleteWindowsOld.ps1" 0x87d01106 execmgr 18/04/2018 16:08:55 8240 (0x2030)
Fatal error 0x87d01106 enountered for program CleanMgr. This program will not retry. execmgr 18/04/2018 16:08:55 8240 (0x2030)
Requesting MTC to delete task with id: {7A861C8B-7075-426A-A3C8-8781FE53AEBA} execmgr 18/04/2018 16:08:55 8240 (0x2030)
