I have a problem with my SCCM and I don't know how to solve it. I read everything I could find about this problem but I still have no solution for it.
Yesterday everything went well, my test machine was pxe-booting, the os-deployment worked and I was also able to distribute software packages. But then while distributing some software packages the client suddenly stopped to install any packages and when I started the second test machine I had a pxe-boot problem. And now I can't pxe-boot any client.
No Boot Action for Device (2843) found smspxe 22.01.2010 12:19:38 4916 (0x1334)
ProcessDatabaseReply: No Advertisement found in Db for device smspxe 22.01.2010 12:19:38 4916 (0x1334)
I checked the boot images, the task sequence, the network access account, the permissions on the images but everything is as it should be (and as it was before, when the pxe-boot worked).
Has anybody got an idea how to solve this problem?
Hi
When I'm booting the client it looks like this:
In the smspxe.log I found the following:
thanks a lot
