daboy85
Prompt for IP Address or TCP/IP Settings
Good evening
I am using SCCM to leverage imaging. I have been asked to do the following
Lay down a new image
rename the computer in the pxe menu (using OSDCOMPUTERNAME Variable) for prompt
Join domain (using Task Sequence)
Allow end user to specify static IP address, gateway (prompt)
I would perferable like to have all prompts in the beginning of the wizard.
I tried a few things and i've come up with nothing. Anyone that can help would help me immensely
I have tried to set the OSDHCP variable to false and similarly to osdcomputername use
osdadapter0gateways and the similar ipaddreses one, but they dont keep the settings.
Edited by daboy85
0 answers to this question
