HectorRP
Help with migrating, not copying a deployment share
Hi guys,
We've been using MDT for a while now and had it close to "perfect" for our deparment needs.  All of a sudden, today we can't no longer connect to the deployment share and get any images.  The process crashes with this error:  a connection to the deployment share could not be made.  Possible invalid credentials.  We've already checked 'customesettings.ini' and 'boot.ini' for anything missing. They're both OK.  We think it may have something to do with the Tech that used to handle MDT leaving the company and his AD account was somehow connected to the process.  Now that he's gone and the account is disabled, it may be causing MDT to not respond.  So that's the backstory on our situation.
This is what I'd like to do:
Create a new deployment share
Then migrate the images, task sequences, etc to the new share
It will all be done within the same server, same drive.  Is this a possibility?  I don't want to start from sratch since everything on the broken share minus the credentials error is ready to go.
Thank you.
0 answers to this question
