mkuriel
Fail to run diskpart on a device
I am failing to run diskpart on a device via SCCM TS, it is a standard SCCM TS - I am booting from pxe and trying to wipe the disk with no luck....
the Device is hp elitebook 830 g5 and I see the same issue with Lenovo m710q
here is the error that i am getting
<![LOG[==============================[ OSDDiskPart.exe ]==============================]LOG]!><time="11:59:19.319-180" date="07-10-2018" component="OSDDiskPart" context="" type="1" thread="1640" file="main.cpp:1078">
<![LOG[Command line: "osddiskpart.exe"]LOG]!><time="11:59:19.319-180" date="07-10-2018" component="OSDDiskPart" context="" type="1" thread="1640" file="main.cpp:1079">
<![LOG[Succeeded loading resource DLL 'X:\sms\bin\i386\1033\TSRES.DLL']LOG]!><time="11:59:19.319-180" date="07-10-2018" component="OSDDiskPart" context="" type="1" thread="1640" file="util.cpp:972">
<![LOG[Reading partition size info for partition 0]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:461">
<![LOG[Remaining size before partition: 512105932800]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:465">
<![LOGLOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:483">
<![LOG[Set partition size: 367001600]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:541">
<![LOG[Remaining size after partition 0: 511738931200]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:618">
<![LOG[Set an environment variable for partitions 0-1 without drive letter]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="1" thread="1640" file="main.cpp:641">
<![LOG[Reading partition size info for partition 1]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:461">
<![LOG[Remaining size before partition: 511738931200]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:465">
<![LOGLOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:478">
<![LOG[99% size specified.]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:528">
<![LOG[Calculated partition size: 506621541888]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:530">
<![LOG[Remaining size after partition 1: 5117389312]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:618">
<![LOG[Set an environment variable for partitions 0-2 with drive letter]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="1" thread="1640" file="main.cpp:641">
<![LOG[Reading partition size info for partition 2]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:461">
<![LOG[Remaining size before partition: 5117389312]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:465">
<![LOG[100% size specified.]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:524">
<![LOG[Remaining size after partition 2: 0]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:618">
<![LOG[Set an environment variable for partitions 0-1;0-3 without drive letter]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="1" thread="1640" file="main.cpp:641">
<![LOG[Checking volume 'X:' for BitLocker]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="1" thread="1640" file="main.cpp:317">
<![LOG[S partition is not used, will use it.]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="1" thread="1640" file="diskutils.cpp:98">
<![LOG[Diskpart: list volume
select disk 0
clean
create partition Primary size=350
assign letter=S
format quick fs=ntfs label="System Reserved"
active
create partition Primary size=483151
assign
create partition primary id=27
format quick fs=ntfs label="Recovery"
rescan
 list volume
]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="1" thread="1640" file="diskutils.cpp:2600">
<![LOG[Executing diskpart script: list volume
select disk 0
clean
assign letter=S
active
assign
rescan
 list volume
]LOG]!><time="11:59:19.350-180" date="07-10-2018" component="OSDDiskPart" context="" type="1" thread="1640" file="diskutils.cpp:1968">
<![LOG[Command line for extension .exe is "%1" %*]LOG]!><time="11:59:19.366-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="CommandLine.cpp:229">
<![LOG[Set command line: "X:\WINDOWS\system32\diskpart.exe" /s "X:\WINDOWS\TEMP\DiskPartScript.txt"]LOG]!><time="11:59:19.366-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="CommandLine.cpp:723">
<![LOG[Executing command line: "X:\WINDOWS\system32\diskpart.exe" /s "X:\WINDOWS\TEMP\DiskPartScript.txt"]LOG]!><time="11:59:19.366-180" date="07-10-2018" component="OSDDiskPart" context="" type="1" thread="1640" file="CommandLine.cpp:819">
<![LOG[Process completed with exit code 2147755013]LOG]!><time="11:59:19.413-180" date="07-10-2018" component="OSDDiskPart" context="" type="1" thread="1640" file="CommandLine.cpp:1115">
<![LOG[Diskpart.exe STDOUT:
Microsoft DiskPart version 10.0.17134.1
Copyright (C) Microsoft Corporation.
On computer: MININT-8J6SRFR
There are no volumes.
Disk 0 is now the selected disk.
DiskPart succeeded in cleaning the disk.
Virtual Disk Service error:
The object is not found.
 ]LOG]!><time="11:59:19.413-180" date="07-10-2018" component="OSDDiskPart" context="" type="3" thread="1640" file="diskutils.cpp:1910">
<![LOG[Diskpart.exe STDERR:  ]LOG]!><time="11:59:19.413-180" date="07-10-2018" component="OSDDiskPart" context="" type="3" thread="1640" file="diskutils.cpp:1911">
<![LOG[Diskpart.exe failed (2147755013).  Script file, stdout, and stderr saved in TS log directory.]LOG]!><time="11:59:19.413-180" date="07-10-2018" component="OSDDiskPart" context="" type="3" thread="1640" file="diskutils.cpp:1939">
<![LOG[0, HRESULT=80042405 (main.cpp,1270)]LOG]!><time="11:59:19.413-180" date="07-10-2018" component="OSDDiskPart" context="" type="0" thread="1640" file="main.cpp:1270">
<![LOG[OSDDiskPart.exe failed: 0x80042405]LOG]!><time="11:59:19.413-180" date="07-10-2018" component="OSDDiskPart" context="" type="3" thread="1640" file="main.cpp:1330">
<![LOG[Process completed with exit code 2147755013]LOG]!><time="11:59:19.413-180" date="07-10-2018" component="TSManager" context="" type="1" thread="1432" file="CommandLine.cpp:1115">
<![LOG[!--------------------------------------------------------------------------------------------!]LOG]!><time="11:59:19.413-180" date="07-10-2018" component="TSManager" context="" type="1" thread="1432" file="instruction.cxx:814">
this is the Diskpart Output:
this is the script that SCCM tries to run on the device
list volume
select disk 0
clean
assign letter=S
active
assign
rescan
list volume
any idea why i am crashing ???
I am attaching the full logs also for reference.
Thank you in advance
diskpart_err.log
diskpart_out.log
diskpart_script.log
smsts.log
Expand
It appears that the virtual disk is Disk 0 which is why the Virtual Disk Service is throwing the error.  Most likely, the physical disk is not detected.
1. Make sure you have the WinPE SATA drivers for that model installed
2. Make sure the physical disk is detected by diskpart
3. Make sure the disk you want to use is actually Disk 0 and not Disk 1 or something else (this happens with multi-drive systems where one is normal SATA and there is an NVMe drive (which shows up as Disk 1)).
