26 minutes ago, amit paul said:
Unfortunately I tried all troubleshooting however CSS failed to provide any possible solution after two days troubleshooting.
Make sure that CSS credits your account for the failed case.
4 hours ago, amit paul said:
issue got resolved after solving SQL server configuration manager issues.
Open a command prompt as administrator
Navigate to your SQL version’s shared directory (cd <version path>):
SQL 2008:  C:\Program Files (x86)\Microsoft SQL Server\90\Shared\
SQL 2008 R2:  C:\Program Files (x86)\Microsoft SQL Server\100\Shared\
SQL 2012:  C:\Program Files (x86)\Microsoft SQL Server\110\Shared\
SQL 2014:  C:\Program Files (x86)\Microsoft SQL Server\120\Shared\
Then run the following command:
mofcomp sqlmgmproviderxpsp2up.mof
1802 Upgrade successfully completed.
The funning is I have a rough draft blog post mostly written on how to install the SQL WMI providers. The WMI providers seem to be removed when you applied some of the SQL SU. It wasn't something I thought of when you posted here.
