Hello Guys,
We have the Problem that our Surface wont boot from Network.
The last Message we get is "nbp file downloaded successfully"
When i use the same TS an USB-Stick it works fine.. a normal HP Workstation over Legacy installation works fine..
Any ideas?
best Regards
Edited by Ranighte
We've had problems with Surface Pro 4 PXE too.  Microsoft have confirmed it's a problem with the UEFI Network stack, and you need to have IPv6 enabled and routed to the PXE Server.  If you just have IPv4 then it won't work.  They are working on a firmware fix, which should be out in a few months.
