Connect-ConfigMgr64 - Function to connect to CMSite (SCCM) # Feedback for Improvement?
Hi WN
I created a function to connect to the CMSite and load the cmdlet for ConfigurationManager.
Could the function be improved in any way or is it as good it can be? is the logic best practice or?
You can download it at : https://gallery.technet.microsoft.com/Connect-ConfigMgr64-db5e9d0a
function Connect-ConfigMgr64
	$initParams = @{ }
	if ((Get-Module ConfigurationManager) -eq $null)
		try
			Import-Module "$($ENV:SMS_ADMIN_UI_PATH)\..\ConfigurationManager.psd1" @initParams -Scope Global
		catch
			$ModulePath = (Get-ItemProperty HKLM:\SOFTWARE\Wow6432Node\Microsoft\ConfigMgr10\Setup -Name "UI Installation Directory").'UI Installation Directory'
			Import-Module $ModulePath\bin\ConfigurationManager.psd1 -Scope Global
	if ((Get-Module ConfigurationManager) -ne $null)
		$SiteCode = Get-PSDrive -PSProvider CMSITE
		if ((Get-PSDrive -Name $SiteCode -PSProvider CMSite -ErrorAction SilentlyContinue) -eq $null)
			$ProviderMachineName = (Get-ItemProperty HKLM:\SOFTWARE\Wow6432Node\Microsoft\ConfigMgr10\AdminUI\Connection -Name Server).Server
			New-PSDrive -Name $SiteCode -PSProvider CMSite -Root $ProviderMachineName @initParams
		if ((Get-PSProvider -PSProvider CMSite) -ne $null)
			Set-Location $SiteCode":\"
			Write-Host 'Type "Get-Command -Module ConfigurationManager" for a list of SCCM CMDlets.' -ForegroundColor Green
		else
			$CustomError = [String]"Error: Can't find CMSite provider"
			Throw $CustomError
	else
		$CustomError = [String]"Unable to locate System Center Configuration Manager installation folder!"
		Throw $CustomError
Connect-ConfigMgr64
