wanderer
How to tell which users installed an application and when
With SCCM 2007 I could use Advertisement Status to check when a PC received an advertisement and when a user started a program.  I would like to be able to duplicate this functionality in SCCM CB 1806.  For a Package/Program I can see under "Summarization Time" when the Program started. However when looking under Deployments for Applications there is no "Summarization Time" option available. Is there anyway of getting this info to display under Deployments? If not is there a report I can run that will show this info?  I've had a look but can't see anything relevant. What I want is when I deploy an application either as Available or Required to see when it was installed on a particular PC.
Thanks in advance for your help.
