hi MrBigTed, thanks for the thanks :)
i'm not following exactly what you are saying, are you saying you've already setup azure ad connect and are also hybrid azure ad joined ?
When deploying self service portals, i got such error when running PS script.
Unable to export ConfigMgr SQL Server Identification Certificate: Unable to find tpye [X509Certificate].
But i got certificate etc.
Edited by Eduards
what command line did you use to install the portals ? if you specified -SqlInstanceName MSSQLSERVER then this error is expected...
if you are using the default instance then leave out that switch
  On 4/8/2020 at 7:29 AM, Eduards said:
Expand
I was able to fix the problem by editing the installer script. Just added a session variable to avoid the proxy.
https://social.technet.microsoft.com/Forums/en-US/1ff999c3-f8d2-4dd2-bd17-df9fc79b8ec2/1910-setting-up-mbam-issues?forum=ConfigMgrCBGeneral
function Get-CertificateFromSqlServer
    param(
        [Parameter(Mandatory=$true)]
        [string]$sqlServer
    $option = New-PSSessionOption -ProxyAccessType NoProxyServer ### added fix for WinRm error
    [array]$encodedCerts = Invoke-Command -ComputerName $sqlServer -ScriptBlock {
        Get-ChildItem -Path Cert:\LocalMachine\My | Where-Object { ($_.FriendlyName -eq "ConfigMgr SQL Server Identification Certificate") -and ($_.NotBefore -lt (Get-Date)) -and ($_.NotAfter -gt (Get-Date)) } | ForEach-Object {
            $bytes = $_.Export("cert");
            [Convert]::ToBase64String($bytes)
    } -SessionOption $option ### added fix for WinRm error
