nizar
problem capture a reference machine
3 answers to this question
please stop raising new topics for the same problem, we need more details about what you've done, and how you are doing it.
is this still the same problem as before, adobe software not appearing after the capture ?
niall
please provide DETAILS of your problem,
there's a capture windows 7 guide here, did you try it ?
did you see if adobe whatever (because you never told us) is in add remove programs after the capture ?
can you give us some actual details of the actual problem ?
