alloa13
ts running successfully but os was not being installed
Hi
Based on your step-by-step guide for how to deploy w2k8 with sccm07, i have build a task sequence.
the ts begins to run, settings being captured, client reboots to boot image, but os image is not being installed.
the report of the ts looks like this:
Report Name: Advertisement status messages for a particular client and advertisement
Category: Software Distribution - Advertisement Status
Comment: This report shows the status messages reported for a particular computer and advertisement.
Parameters: Advertisement ID JIZ20052
Computer Name ******
09.02.2010 08:57:48 (Number of Records: 43)
Time Message State Name Message Name Message ID Record ID
09.02.2010 08:52:52 Waiting Waiting for content 10035 254923
09.02.2010 08:52:54 Accepted Program received 10002 254924
09.02.2010 08:52:55 Running Program started 10005 254925
09.02.2010 08:52:57 Running The task sequence execution engine started execution of a task sequence 11140 254926
09.02.2010 08:52:57 Running The task sequence execution engine started a group 11124 254927
09.02.2010 08:52:57 Running The task sequence execution engine started a group 11124 254928
09.02.2010 08:52:57 Running The task sequence execution engine skipped a disabled action 11128 254929
09.02.2010 08:52:57 Running The task sequence execution engine skipped an action because the condition was evaluated to be false 11130 254930
09.02.2010 08:53:39 Running The task sequence execution engine successfully completed an action 11134 254932
09.02.2010 08:53:40 Running The task sequence execution engine successfully completed an action 11134 254933
09.02.2010 08:53:42 Running The task sequence execution engine successfully completed an action 11134 254935
09.02.2010 08:53:42 Running The task sequence execution engine successfully completed execution of a group 11127 254936
09.02.2010 08:53:42 Running The task sequence execution engine started a group 11124 254937
09.02.2010 08:53:42 Running The task sequence execution engine started a group 11124 254938
09.02.2010 08:53:43 Running The task sequence execution engine successfully completed an action 11134 254939
09.02.2010 08:53:44 Running The task sequence execution engine successfully completed an action 11134 254940
09.02.2010 08:53:44 Running The task sequence execution engine successfully completed execution of a group 11127 254942
09.02.2010 08:53:44 Running The task sequence execution engine successfully completed execution of a group 11127 254943
09.02.2010 08:53:44 Running The task sequence execution engine started a group 11124 254944
09.02.2010 08:53:45 Running The task sequence execution engine successfully completed an action 11134 254945
09.02.2010 08:53:46 Running The task sequence execution engine successfully completed an action 11134 254946
09.02.2010 08:53:46 Running The task sequence execution engine successfully completed execution of a group 11127 254947
09.02.2010 08:53:46 Running The task sequence execution engine started a group 11124 254948
09.02.2010 08:53:46 Running The task sequence execution engine skipped a group because the condition was evaluated to be false 11122 254949
09.02.2010 08:53:46 Running The task sequence execution engine successfully completed execution of a group 11127 254950
09.02.2010 08:53:47 Running The task sequence execution engine started a group 11124 254951
09.02.2010 08:53:47 Running The task sequence execution engine started a group 11124 254952
09.02.2010 08:53:47 Running The task sequence execution engine successfully completed an action 11134 254953
09.02.2010 08:54:32 Running The task sequence execution engine performed a system reboot initiated by an action 11142 254956
09.02.2010 08:56:08 Running The task sequence execution engine started execution of a task sequence 11140 254960
09.02.2010 08:56:10 Running The task sequence execution engine successfully completed an action 11134 254961
09.02.2010 08:56:12 Running The task sequence execution engine successfully completed an action 11134 254962
09.02.2010 08:56:13 Running The task sequence execution engine failed executing an action 11135 254963
09.02.2010 08:56:13 Running The task sequence execution engine ignored execution failure of an action 11138 254964
09.02.2010 08:56:36 Running The task sequence execution engine failed executing an action 11135 254965
09.02.2010 08:56:36 Running The task sequence execution engine started a group 11124 254966
09.02.2010 08:56:36 Running The task sequence execution engine successfully completed an action 11134 254967
09.02.2010 08:56:39 Running The task sequence execution engine successfully completed an action 11134 254970
09.02.2010 08:57:09 Running The task sequence execution engine successfully completed an action 11134 254971
09.02.2010 08:57:10 Running The task sequence execution engine successfully completed an action 11134 254972
09.02.2010 08:57:10 Running The task sequence execution engine successfully completed execution of a group 11127 254973
09.02.2010 08:57:10 Succeeded The task sequence execution engine successfully completed a task sequence 11143 254974
09.02.2010 08:57:10 Succeeded The task sequence manager successfully completed execution of the task sequence 11171 254975
the two errors saying this:
The task sequence execution engine failed executing the action (Request State Store) in the group (Refresh Only) with the error code 50 Action output: . The operating system reported error 50: The request is not supported.
The task sequence execution engine failed executing the action (Backup) in the group (Refresh Only) with the error code 2 Action output: 5.0.1641.0 The task sequencer log is located at X:\windows\TEMP\SMSTSLog\SMSTS.LOG. For task sequence failures, please consult this log. Drive C: 9073644 Local store path = C:\_SMSTaskSequence\StateStore Total used space: 9073644 Available space atC:\_SMSTaskSequence\StateStore: 22389624 Backup can use local path Property OSDStateStorePath is now = Computer backup will use network path (ComputerBackupLocation=AUTO) WARNING - Unable to validation connection because a blank UNC was specified.Beginning backup of drive C: About to run command: cmd /c ""C:\_SMSTaskSequence\WDPackage\Tools\X64\imagex.exe" /capture /compress maximum C: "\*****.wim" "201002091756CDrive" >> X:\windows\TEMP\SMSTSLog\ZTIBackup_imagex.log 2>&1" Process completed with exit code 2 Return code from command = 2 Error creating an image of drive C:, rc = 2 ztibackup COMPLETED. Return Value = 2 Property BackupScriptComplete is now = YES ZTI ERROR - Non-zero return code by ztibackup, rc = 2 Command line returned 2. The operating system reported error 2: The system cannot find the file specified.
Any ideas what the problem could be?
thanks
0 answers to this question
