bart dm
portable without internet lan card > usb displaylink dock losing connection
dear all
we are staging with windows version 1809
On the win pe part we've integraded the displaylink lan drivers and we recieve an ip
problem is after the winpe part, the usb adapter is losing connection and doesnt reinitialise
We've integraded the dell proposition to do a usb port reset using devcon, but this doesnt work
if somebody has the same problem?
portable is a dell latitude 5300 2-in-1 and universal docking is a kensington sd3500v (with displaylink drivers)
thank you all
Bart
