hi all,
  Quote
/offlinewindir: "path to a windows directory"
This option specifies the offline Windows directory that the ScanState command gathers user state from. The offline directory can be Windows.old when you run the ScanState command in Windows or a Windows directory when you run the ScanState command in Windows PE. This option is incompatible with the /offline option.
The theory behind this:-
Get your lab ready
The Task Sequence
Offline Mode in Windows PE using USMT 4.xmlFetching info...
SET
CREATE
and c:\USMTbits\X86
XCOPY
runscanstate-offlinewindir.bat.txtFetching info...
RUN
Testing Offline Mode.
browse it and verify
smsts.logFetching info...
Ok now what ?
copy the batch file to a folder, in configmgr software distribution, select packages right click, choose new package, point to the folder, done. Distribute it to a dp. thats it
Thank you very much!one more question...I take an error when running ofline task sequence from last step x86 do runscanstate(0x00000001) and it stops.Also i can see in log an error runscanstate-offlinewindir.bat is not recognized as an internal or external command.That error is when i take the steps online.When i do it from pxe boot i take a error 0x80004005!Any help for both problems?
Also i can see some failed point to my logs
SMSTS.LOG
Failed to run the action: do X86 scanstate.
Incorrect function. (Error: 00000001; Source: Windows)
The execution of the group (Run) has failed and the execution has been aborted. An action failed.
Operation aborted (Error: 80004004; Source: Windows)
Task Sequence Engine failed! Code: enExecutionFail
smsts-20101112-021854.log
Failed to connect to "\\LAB-SCCM-01.DOMAIN.LOCAL\SMSPXEIMAGES$\SMSPKG\ABC00005"
Any help appreciated
It is hard to say with these failed sentances direclly.There should be other information after and before task action failed. It would be easier for us if you post smsts.log for other info as well.
  Quote
this could be because of command line syntax errors for do X86 scanstate or not having the required USMT package?
  Quote
it is failed to connect to ABC00005(might be boot image),also problem could be network breakdown issues or secury rights(may be NAAccount ) while connecting to PXE DP package but after this messgege ,client should have tried connecting again to this package successfully i think.
  On 11/11/2010 at 4:33 PM, panos83 said:
Thanks for your answer.I have attached the 2 logs i mention.Please have a look any comment appreciated.smsts.logsmsts-20101112-021854.log
the bat file package is download and saved to 'c:\USMTbits\ but failed to execute. There is something wrong with your batch file creation .Check if you have created the correct bat file or not ? like cmd.exe /c batfilename.bat also ensure you have created package with correct files into it.
  Quote
Set command line: Run command line
Working dir 'c:\USMTbits\'
Executing command line: Run command line
Process completed with exit code 1
'runscanstate-offlinewindir.bat' is not recognized as an internal or external command,
operable program or batch file.
  On 11/12/2010 at 12:29 PM, jdelvasto said:
This guide is excellent. My question is do the default .xml files need to modified (Miguser.xml, MigDocs.xml, MigApp.xml) and if so what are the changes for offline USMT to work?
By default,Miguser.xml, MigDocs.xml, MigApp.xml will have all settings which are required to migrate. Take a look at here what these migration xml files contains http://technet.microsoft.com/en-us/library/cc766203(WS.10).aspx
Are you looking for some specific settings or applications to be migrated? IF so,you might need to create or edit the existing xml file based on the requirement,
