hi all,
/offlinewindir: "path to a windows directory"
This option specifies the offline Windows directory that the ScanState command gathers user state from. The offline directory can be Windows.old when you run the ScanState command in Windows or a Windows directory when you run the ScanState command in Windows PE. This option is incompatible with the /offline option.
The theory behind this:-
Get your lab ready
The Task Sequence
Offline Mode in Windows PE using USMT 4.xml
SET
CREATE
and c:\USMTbits\X86
XCOPY
runscanstate-offlinewindir.bat.txt
RUN
Testing Offline Mode.
browse it and verify
smsts.log
Ok now what ?
This post/process rocks! I love the offline migration! I have several computers that the SCCM client was jacked up on, they would not take the advertisement so I PXE booted them and whalah! I added the printers.xml file to my package and it migrated mapped network drives, networked printers….man I am one happy camper!!!!!
Once question, should the c:\USMToffline directory still exist after a successful migration? Or should it be deleted at the end? The reason I ask is mine is still present but I don’t know if I was doing something wrong?
Thanks for this post, it was a lifesaver! Now if anyone can find an actual way for 802.1x to work with OSD/PXE I will be sending them my first born! :P
How to create a RunScanstate package? i have already downloaded the batchfile. Help pls.
Its line creation of normal package.
1.Copy the batch file into a folder(name is as you like)
2.Go to SCCM console,packages node,click on New package and select souce as above package (either could be local Network or Network share).
3.make it avilable on DP.
Thanks for your quick reply
