- 0
Asked by
Asked by
hi all,
The theory behind this:-
Get your lab ready
The Task Sequence
Offline Mode in Windows PE using USMT 4.xmlFetching info...
SET
CREATE
and c:\USMTbits\X86
XCOPY
runscanstate-offlinewindir.bat.txtFetching info...
RUN
Testing Offline Mode.
browse it and verify
smsts.logFetching info...
Ok now what ?
