hi all,
/offlinewindir: "path to a windows directory"
This option specifies the offline Windows directory that the ScanState command gathers user state from. The offline directory can be Windows.old when you run the ScanState command in Windows or a Windows directory when you run the ScanState command in Windows PE. This option is incompatible with the /offline option.
The theory behind this:-
Get your lab ready
The Task Sequence
Offline Mode in Windows PE using USMT 4.xml
SET
CREATE
and c:\USMTbits\X86
XCOPY
runscanstate-offlinewindir.bat.txt
RUN
Testing Offline Mode.
browse it and verify
smsts.log
Ok now what ?
I'm hoping someone can help with this!
As stated in my above post, the "do runscanstate x86" step takes forever... after examining my smsts.log... it's almost as if it's not even doing anything for an entire half hour - THEN it starts to migrate the profiles and shows the percentages.
Also - since then, for whatever reason, it's telling me my boot image is inaccessible, and thus, my TS fails directly after the scanstate.
I've attached my smsts.log ...PLEASE someone help!
smsts.log
scanstate works fine see here > Successfully complete the action (do X86 scanstate) with the exit win32 code 0
after that it trys to apply the operating system (are you sure the OS wim image is correct ?)
<![LOG[Not a data image]LOG]!><time="16:11:14.844+240" date="09-09-2011" component="ApplyOperatingSystem" context="" type="0" thread="408" file="applyos.cpp:320">
<![LOG[ApplyOSRetry: ]LOG]!><time="16:11:14.844+240" date="09-09-2011" component="ApplyOperatingSystem" context="" type="0" thread="408" file="applyos.cpp:331">
<![LOG[TSLaunchMode: UFD]LOG]!><time="16:11:14.844+240" date="09-09-2011" component="ApplyOperatingSystem" context="" type="0" thread="408" file="applyos.cpp:332">
<![LOG[OSDUseAlreadyDeployedImage: FALSE]LOG]!><time="16:11:14.844+240" date="09-09-2011" component="ApplyOperatingSystem" context="" type="0" thread="408" file="applyos.cpp:333">
<![LOG[Rebooting and retrying]LOG]!><time="16:11:14.844+240" date="09-09-2011" component="ApplyOperatingSystem" context="" type="0" thread="408" file="applyos.cpp:345">
<![LOG[Process completed with exit code 0]LOG]!><time="16:11:14.844+240" date="09-09-2011" component="TSManager" context="" type="1" thread="1708" file="commandline.cpp:1102">
<![LOG[!--------------------------------------------------------------------------------------------!]LOG]!><time="16:11:14.844+240" date="09-09-2011" component="TSManager" context="" type="1" thread="1708" file="instruction.cxx:3010">
<![LOG[successfully complete the action (Apply Operating System) with the exit win32 code 0
and that appears to complete ok, it then claims it needs to retry (possibly due to bad image ?)
<![LOG[The action (Apply Operating System) requested a retry]LOG]!><time="16:11:14.954+240" date="09-09-2011" component="TSManager" context="" type="1" thread="1708" file="engine.cxx:263">
<![LOG[Reboot to WinPE]LOG]!><time="16:11:14.954+240" date="09-09-2011" component="TSManager" context="" type="1" thread="1708" file="engine.cxx:453">
<![LOG[Calling RebootSystem()]LOG]
[staging boot image DOT00001]LOG]!><time="16:11:14.954+240" date="09-09-2011" component="TSManager" context="" type="1" thread="1708" file="bootimage.cpp:672">
<![LOG[0, HRESULT=80004005 (e:\nts_sms_fre\sms\framework\tscore\encryptablevolume.cpp,368)]LOG]!><time="16:11:15.344+240" date="09-09-2011" component="TSManager" context="" type="0" thread="1708" file="encryptablevolume.cpp:368">
<![LOG[Checking to see if the data path is on a bootable volume]LOG]!><time="16:11:15.344+240" date="09-09-2011" component="TSManager" context="" type="1" thread="1708" file="bootimage.cpp:939">
<![LOG[buffer was too small to get disk layout. Trying again with 1248 bytes]LOG]!><time="16:11:15.344+240" date="09-09-2011" component="TSManager" context="" type="1" thread="1708" file="diskutils.cpp:1269">
<![LOG[0, HRESULT=80004005 (e:\nts_sms_fre\sms\framework\tscore\encryptablevolume.cpp,368)]LOG]!><time="16:11:15.359+240" date="09-09-2011" component="TSManager" context="" type="0" thread="1708" file="encryptablevolume.cpp:368">
<![LOG[boot Image not found in local data cache. Staging is required
then it claims the boot image is not found (you are using multicasting here it seems also ?)
<![LOG[Boot Image package not found.
Unspecified error (Error: 80004005; Source: Windows)]LOG]!><time="16:13:15.386+240" date="09-09-2011" component="TSManager" context="" type="3" thread="1708" file="bootimage.cpp:1002">
so is the boot image distibuted to both dps ? is your image wim a valid captured OS ?
Yes the scanstate action completed with no errors, but if you look here, I get the "Starting the Migration Process" (the first step of the USMT) appears at 15:36, and then it doesn't start the first gathering of profile data until 16:10... if I run the USMT from a full OS standpoint, the gathering of the profile data starts almost immediately. It seems as though there's definitely a hold up here, and the ts is idle for about 30 minutes during the 'run scanstate x86' portion:
<![LOG[Starting the migration process]LOG]!><time="15:36:17.171+240" date="09-09-2011" component="InstallSoftware" context="" type="1" thread="1812" file="runcommandline.cpp:34">
<![LOG[Offline engine startup from WinDir - c:\windows]LOG]!><time="16:10:33.614+240" date="09-09-2011" component="InstallSoftware" context="" type="1" thread="1812" file="runcommandline.cpp:34">
<![LOG[Processing the settings store]LOG]!><time="16:10:33.614+240" date="09-09-2011" component="InstallSoftware" context="" type="1" thread="1812" file="runcommandline.cpp:34">
<![LOG[]LOG]!><time="16:10:33.614+240" date="09-09-2011" component="InstallSoftware" context="" type="1" thread="1812" file="runcommandline.cpp:34">
<![LOG[Examining the system to discover the migration units]LOG]!><time="16:10:33.614+240" date="09-09-2011" component="InstallSoftware" context="" type="1" thread="1812" file="runcommandline.cpp:34">
<![LOG[ S-1-5-21-1210859283-1907650544-1231754661-71091 (SWDist) (1 of 4): 0% done ]LOG]!><time="16:10:33.879+240" date="09-09-2011" component="InstallSoftware" context="" type="1" thread="1812" file="runcommandline.cpp:34">
<![LOG[ S-1-5-21-1210859283-1907650544-1231754661-71091 (SWDist) (1 of 4): 42% done ]LOG]!><time="16:10:33.879+240" date="09-09-2011" component="InstallSoftware"
As for the OS image, there shouldn't be any problems with it. There's nothing out of the ordinary on the WIM file, and I've used it countless times in my standalone Windows 7 Base Image task sequence. Correct me if I'm wrong, but the steps here would be:
Scanstate
Stage the boot image
Apply the Operating System
It seems as though the root of the problem is that the boot image is not being loaded successfully (although it works fine from another TS), and yes, I've updated the x86 boot image on both DPs. Why would it try to apply the operating system before the boot image is even loaded?
As for the scanstate.log, that's the one thing I am going to check as soon as I get back to the office on Monday. I was about to examine it briefly on Friday evening before I left, but I checked both C:\USMTbits\x86 and X:\Windows\temp and I did not see it listed there from within the command shell.
Thanks in advance for your help guys! I really want to tackle this.
I seem to be getting a weird error...
The task sequence execution engine failed executing the action (xcopy X86 USMT to USMTbits\X86) in the group (xcopy) with the error code 4
Action output: es\sp10002b\x86\replacementmanifests\microsoft-windows-terminalservices-licenseserver is a directory. Setting directory security
c:\_smstasksequence\packages\sp10002b\x86\replacementmanifests\usb is a directory. Setting directory security
c:\_smstasksequence\packages\sp10002b\x86\replacementmanifests\windowssearchengine is a directory. Setting directory security
Content successfully downloaded at C:\_SMSTaskSequence\Packages\SP10002B
Resolved source to 'C:\_SMSTaskSequence\Packages\SP10002B'
Set command line: Run command line
Working dir 'C:\_SMSTaskSequence\Packages\SP10002B'
Executing command line: Run command line
‰????????Process completed with exit code 4
Command line returned 4
Entering ReleaseSource() for C:\_SMSTaskSequence\Packages\SP10002B
reference count 1 for the source C:\_SMSTaskSequence\Packages\SP10002B before releasing
Delete source directory C:\_SMSTaskSequence\Packages\SP10002B
Invalid drive specification
Released the resolved source C:\_SMSTaskSequence\Packages\SP10002B. The operating system reported error 4: The system cannot open the file.
It creates the two folders for USMTbits & Offline?
sp10002b is my USMT package??? I've tried updating the DP?
Any ideas? It only seemed to stop working since I put the workaround path into XCOPY....
This is the path I'm using...
xcopy %_SMSTSSP10002B%* %USMTDrive%\USMTbits /herciy
Looking into SMSTS.log
I can see
Content location request for SP100014:1 failed. (Code 0x80040102)
But looking through all my packages, os & task sequences I cannot find a reference for SP100014 ????
Any ideas?
I'm thinking it must be something to do with my scan state package...does it need a program ??? I've just dropped the batch file into a folder and pointed the source files to that folder in the package?
pss53, I'm pretty sure that the runstanstate.bat does NOT need a program from within the package... it was working for me without one just last week.
Alas, I'm still stuck. However, in case anyone is interested, I was able to determine *why* the runscanstate.bat was taking so long.... this was because in the scanstate.log file, it was trying to copy profiles that were absent in reality and had no ntuser.dat file, but still existed as a SID # within the registry (but had no profile data to be found). Therefore, it was trying to copy each of these nonexistent profiles about twenty times each, failing each time since it could not find the data in C:\Documents and Settings, and waiting six seconds between each retry. I was able to circumnavigate this issue by using the following line in the runscanstate.bat:
SET MIG_IGNORE_PROFILE_MISSING=1
Now my other issue is still the boot image. Is it normal for the boot image to be copied to C:\_SMSTaskSequence\Packages\DOT0001 (the last part being the package identifier of my x86 boot image)? I read earlier in this thread that you need to have the advertisement set to "download content when needed by task sequence" instead of the "access content directly," so I set it as such. I do have my boot image set to "Allow transfer over multicast (winPE only)" and "Encrypt multicast packages"; should this make a difference?
Also, I've tried a substitute boot image, an alternate operating system image, and I've tried re-advertising the task sequence.. so that rules those out. Therefore, I'm almost certain that it's an issue within either the properties of the boot image, or the properties of the specific advertisement..
In my smsts log file, I see:
Unspecified error (Error: 80004005; Source: Windows) TSManager 9/12/2011 10:20:20 AM 1752 (0x06D8)
Entering ReleaseSource() for C:\_SMSTaskSequence\Packages\DOT00001 TSManager 9/12/2011 10:20:20 AM 1752 (0x06D8)
The user tries to release a source directory C:\_SMSTaskSequence\Packages\DOT00001 that is either already released or we have not connected to it TSManager 9/12/2011 10:20:20 AM 1752 (0x06D8)
BootImage::ResolveImageSource( pszPackageId, sImagePackageSourcePath, sImageSourcePath), HRESULT=80004005 (e:\nts_sms_fre\sms\framework\tscore\bootimage.cpp,687) TSManager 9/12/2011 10:20:20 AM 1752 (0x06D8)
TS::Boot::BootImage::StageBootImage(sBootImageID, StageBootImageProgressCallback, (LPVOID) m_sStageBootImageMessage.c_str()), HRESULT=80004005 (e:\nts_sms_fre\sms\client\tasksequence\executionengine\engine.cxx,816) TSManager 9/12/2011 10:20:20 AM 1752 (0x06D8)
Failed to stage a boot image DOT00001.
Unspecified error (Error: 80004005; Source: Windows) TSManager 9/12/2011 10:20:21 AM 1752 (0x06D8)
I'm really not sure what any of this means, aside from the fact that it was unable to download the boot image locally (aka stage), and therefore it cannot launch. I wish this would start working :blink:
Got it... after I unchecked the "Allow this package to be transferred via multicast (WinPE only)" and "Encrypt multicast packages" from within the boot image properties, the TS was able to download and stage the boot image package properly.... I'm not sure yet which one of those settings was the instigator... can anyone enlighten me as to why these options were interfering?
I have run this and on most of my PC's it is working flawlessly. On a few it does not bring the profiles back (they are in USMToffline). I believe it is due to local accounts. But my real question is what can I do to manually bring these back. I assume some sort of command line run using loadstate.exe
You would do a loadstate command using the proper syntax, i.e.:
loadstate C:\USMTBits /i:miguser.xml /i:migapp.xml /uel:60
The syntax is here:
http://technet.micro...28WS.10%29.aspx
I believe if you're running in the WinPE environment, you will need the "/offline:windir:<windows directory path>" switch, and of course the /hardlink and /nocompress switches for the hardlinked data.
