hi all,
/offlinewindir: "path to a windows directory"
This option specifies the offline Windows directory that the ScanState command gathers user state from. The offline directory can be Windows.old when you run the ScanState command in Windows or a Windows directory when you run the ScanState command in Windows PE. This option is incompatible with the /offline option.
The theory behind this:-
Get your lab ready
The Task Sequence
Offline Mode in Windows PE using USMT 4.xml
SET
CREATE
and c:\USMTbits\X86
XCOPY
runscanstate-offlinewindir.bat.txt
RUN
Testing Offline Mode.
browse it and verify
smsts.log
Ok now what ?
Hi - I have managed to get this working in a Test environment but when I have copied it over to a live system I am getting the error below. Does anyone have any advice on what might be causing this?
The task sequence execution engine failed executing the action (do X86 scanstate) in the group (Run) with the error code 29
Action output: =======================[ smsswd.exe ] =======================
PackageID = 'LON00060'
BaseVar = '', ContinueOnError=''
SwdAction = '0001'
No http based locations are available. SMB based locations will be attempted now.
Successfully connected to "\\PackageServerName\SMSPKGD$\LON00060"
Resolved source to 'C:\_SMSTaskSequence\Packages\LON00060'
Working dir 'c:\USMTbits\'
Executing command line: Run command line
c:\USMTbits>"c:\USMTbits\x86\scanstate.exe" "c:\USMToffline" /c /o /hardlink /efs:hardlink /nocompress /offlinewindir:c:\windows /v:5 /l:c:\windows\TEMP\SMSTSLog\scanstate.log /progress:c:\windows\TEMP\SMSTSLog\scanstateprogress.log /i:c:\USMTbits\x86\miguser.xml /i:c:\USMTbits\x86\migapp.xml
Log messages are being sent to 'c:\windows\TEMP\SMSTSLog\scanstate.log'
Starting the migration process
Failed.
Unable to automatically map the drive letters to match the online drive letter layout;
Use /offline to provide a mapping table
See the log file for more information.. The operating system reported error 29: The system cannot write to the specified device.
To add to this - when I resolve this issue I would also like to enable bitlocked in WinPE using the instructions here: http://www.windows-noob.com/forums/index.php?/topic/3875-customising-windows-7-deployments-part-5/
Do you know if this possible as to enable bitlocker the drive needs to be formated but that would then wipe the USMT folders?
Thanks again
try doing it in Windows PE instead, it's designed for Windows PE not Windows.
niall
Anyweb
Hope this will be an easy one for you. I have your steps all the way to: do x86 scanstate. Am only running the loadstate and scanstate process. No OSD on the Task Sequence
Here is what I can see
  1. USMTbits folder is created with the vb script
  2. USMToffline folder is created with sub-foders
But when i navigate to C:\\USMTOffline\USMT\File\c$\users\user1. The profile is blank and no data has been moved.
Any Ideas?
well does your loadstate.log file reveal any issues ?
Anyweb
No loadstate.log that I can find on the system. I have checked on the following location
C:\Windows\System32\CCM\Logs and
C:\SMSTSLog.
I also rerun the TS and verified the loadstate log does not get created on both locations.
Am I looking on the wrong place.
