hi all,
/offlinewindir: "path to a windows directory"
This option specifies the offline Windows directory that the ScanState command gathers user state from. The offline directory can be Windows.old when you run the ScanState command in Windows or a Windows directory when you run the ScanState command in Windows PE. This option is incompatible with the /offline option.
The theory behind this:-
Get your lab ready
The Task Sequence
Offline Mode in Windows PE using USMT 4.xml
SET
CREATE
and c:\USMTbits\X86
XCOPY
runscanstate-offlinewindir.bat.txt
RUN
Testing Offline Mode.
browse it and verify
smsts.log
Ok now what ?
in the configmgr console select your task sequence and click on the references tab, do you see your USMT 4 package as well as the USMT 3 package ? you probably have both packages referenced in the task sequence and will have to go through any step which captures state (or restores it) to fix the package
i am one quick question migration (windows xp to win7) can i have a working hardlink
hi Vishnu,
that is not a question,
what exactly are you trying to do ? are you trying Offline mode in WinPE ? if not then create a new topic explaining what you've tried and what your problem is..
I was wondering if you could help me out. I have created the task sequence from building upon XP to W7 Demo - X86 Offline Mode in WinPE-USMT 4 and I am running it it from a usb drive.
Everything is working fine and the pc is been added to the domain except the users setting are not been restored. The USMT offline folder has been created and is on the C drive.
I have attached the task sequence I am using. Would I need to create a batch file to restore the users profiles rather than use USMT 4 during the restore?
Any help would be much appreciated as I have 5000 pc's and laptops to build over the next year.
XP to W7 Demo - X86 Offline Mode itest.xml
  • I am still getting the same errors on my sequence when it tries to run scanstate in my lab sequence. I have imported the Demo Task sequence and set everything up excalty as in the demo ( i have done this several times.) It's gotta be something small I am missing but every time I get the Invalid Store Argument error. I have not edited any of the XML files. Just trying to run the Proof of concept portion of the script.
2012-05-10 12:40:41, Info [0x000000] USMT Started at 2012/05/10:12:40:41.947
2012-05-10 12:40:41, Info [0x000000] Command line: \USMTbits\x86\scanstate.exe /c /o /hardlink /efs:hardlink /nocompress /offlinewindir:c:\windows /v:5 /l:\windows\TEMP\SMSTSLog\scanstate.log /progress:\windows\TEMP\SMSTSLog\scanstateprogress.log /i:\USMTbits\x86\miguser.xml /i:\USMTbits\x86\migapp.xml
2012-05-10 12:40:41, Status [0x000000] Activity: 'MIGACTIVITY_COMMAND_LINE_PROCESSING'
2012-05-10 12:40:41, Info [0x000000] Failed.[gle=0x00000091]
2012-05-10 12:40:41, Info [0x000000] USMT Status 1033 (STORE_ARGUMENT_ERROR): An error occurred processing the command line.
\USMTbits\x86\scanstate.exe ##ERROR## --> /c /o /hardlink /efs:hardlink /nocompress /offlinewindir:c:\windows /v:5 /l:\windows\TEMP\SMSTSLog\scanstate.log /progress:\windows\TEMP\SMSTSLog\scanstateprogress.log /i:\USMTbits\x86\miguser.xml /i:\USMTbits\x86\migapp.xml
Settings store argument specified is invalid[gle=0x00000091]
2012-05-10 12:40:41, Info [0x000000] USMT Completed at 2012/05/10:12:40:41.962[gle=0x00000091]
2012-05-10 12:40:41, Info [0x000000] Entering MigShutdown method
2012-05-10 12:40:41, Info [0x000000] Leaving MigShutdown method
Hi i was wondering if some could help me with this . my task sequence fails on Running action : xcopy x86 USMT TO USMTbits\x86 with error code 0x00000004
i have set the Set SystemDrive Variable to c
it does create the USMTbits and USMToffline Folders and looks like its download the files as well .
i have also changed my Create and XCOPY command line to the following
Create USMT folder to store USMT packages TO cmd.exe /c md %systemdrive%\USMTbits
xcopy X86 USMT to USMTbits\X86 TO xcopy %_SMSTSCIS00058%* %systemdrive%\USMTbits\ /herciy
I have done this as i want to use the Full USMT Package
i also have attached my TS and log file
smsts.log
ts.xml
Hi all,
I just joined the site today. First and foremost, many sincere thanks to Niall for making such great contributions to these forums. I've been following your posts for a while and decided to join this forum.
One question I have regarding this TS for offline migrations from XP to Win7. Is there a way to incorporate these steps in the MDT 2012 UDI TS w/ SCCM 2007. Currently I have a working MDT 2012 UDI TS on SCCM which is only doing the New Computer scenario. Everything works well. I need to perform some very basic user data backup incl network printer mappings in offline mode. If you could guide me as to where to add these steps so that the UDI wizard can pass the variables correctly to the TS steps, that would be huge help.
I've attached copy of my TS.
Thanks and everyone keep up the great work.
Win 7 with Core Apps.xml
as Peter says, the only way to find out what is working or not with your migration is to examine the scanstate.log and loadstate.log files generated by USMT
