hi all,
  Quote
/offlinewindir: "path to a windows directory"
This option specifies the offline Windows directory that the ScanState command gathers user state from. The offline directory can be Windows.old when you run the ScanState command in Windows or a Windows directory when you run the ScanState command in Windows PE. This option is incompatible with the /offline option.
The theory behind this:-
Get your lab ready
The Task Sequence
Offline Mode in Windows PE using USMT 4.xmlFetching info...
SET
CREATE
and c:\USMTbits\X86
XCOPY
runscanstate-offlinewindir.bat.txtFetching info...
RUN
Testing Offline Mode.
browse it and verify
smsts.logFetching info...
Ok now what ?
pls find the attachment....
SMSTS.log
Apply(), HRESULT=80070091 (e:\nts_sms_fre\sms\client\osdeployment\applyos\installimage.cpp,1456) ApplyOperatingSystem 7/24/2012 5:55:13 PM 268 (0x010C)
Installation of image 1 in package MC100004 failed to complete..
The directory is not empty. (Error: 80070091; Source: Windows) ApplyOperatingSystem 7/24/2012 5:55:13 PM 268 (0x010C)
installer.install(), HRESULT=80070091 (e:\nts_sms_fre\sms\client\osdeployment\applyos\installimage.cpp,1527) ApplyOperatingSystem 7/24/2012 5:55:13 PM 268 (0x010C)
Closing image file \\sccmcentral.micro.com\SMSPKGC$\MC100004\install.wim ApplyOperatingSystem 7/24/2012 5:55:13 PM 268 (0x010C)
Entering ReleaseSource() for \\sccmcentral.micro.com\SMSPKGC$\MC100004\ ApplyOperatingSystem 7/24/2012 5:55:13 PM 268 (0x010C)
reference count 1 for the source \\sccmcentral.micro.com\SMSPKGC$\MC100004\ before releasing ApplyOperatingSystem 7/24/2012 5:55:13 PM 268 (0x010C)
Released the resolved source \\sccmcentral.micro.com\SMSPKGC$\MC100004\ ApplyOperatingSystem 7/24/2012 5:55:13 PM 268 (0x010C)
InstallImage( g_InstallPackageID, g_ImageIndex, targetVolume, ImageType_OS, g_ConfigPackageID, g_ConfigFileName, bOEMMedia ), HRESULT=80070091 (e:\nts_sms_fre\sms\client\osdeployment\applyos\applyos.cpp,373) ApplyOperatingSystem 7/24/2012 5:55:13 PM 268 (0x010C)
Process completed with exit code 2147942545 TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
!--------------------------------------------------------------------------------------------! TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
Failed to run the action: Apply Operating System Image.
The directory is not empty. (Error: 80070091; Source: Windows) TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
Sending status message . . . TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
Send a task execution status message SMS_TSExecution_ActionFailError TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
MP server sccmcentral.micro.com and port 80. SSL=false. CRL=false. TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
Site code: MC1 TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
Client machine name: test TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
Client Identity: GUID:757B4C05-4362-47E6-8E6B-B32D2A2A9781 TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
Advertisement ID: MC120003 TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
Package ID: MC10000D TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
Sending StatusMessage TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
Formatted header: TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
<Msg SchemaVersion="1.1" ReplyCompression="zlib"><ID/><SourceID>298d7826-91bc-45f7-8027-4c8626ffe218</SourceID><SourceHost/><TargetAddress>mp:[http]MP_StatusManager</TargetAddress><ReplyTo>direct:OSD</ReplyTo><Priority>3</Priority><Timeout>3600</Timeout><SentTime>2012-07-24T12:25:13Z</SentTime><Protocol>http</Protocol><Body Type="ByteRange" Offset="0" Length="4256"/><Hooks/><Payload Type="inline"/><TargetHost/><TargetEndpoint>StatusReceiver</TargetEndpoint><ReplyMode>Sync</ReplyMode><CorrelationID/></Msg>
CLibSMSMessageWinHttpTransport::Send: URL: sccmcentral.micro.com:80 CCM_POST /ccm_system/request TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
The request has succeeded. 200 OK TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
Set a global environment variable _SMSTSLastActionRetCode=-2147024751 TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
Set a global environment variable _SMSTSLastActionSucceeded=false TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
Clear local default environment TSManager 7/24/2012 5:55:13 PM 1732 (0x06C4)
i dont see any scanstate or loadstate log files atttached above... however from the small bit of smsts.log file you posted theres the following error
  Quote
which means that a file (or files) are still on the hard disc (probably somewhere in the old users profile) that could not be deleted prior to applying the new os, therefore the installation failed, you'll need to examine the logs to find out what files are causing the issue.
Hello guys,
I am trying to do the XP to W7 Offline and I'm running into some issues.
First I am trying to go from Windows XP x86 to Windows 7 x64.
It goes through Set, Create, xcopy groups just fine, but fails on the Run scanstate part.
I have attached the Task Sequences, scanstate log and the bat file in txt form that I am using.
Any help would be great on this.
Thanks you in advanced you guys have helped me with a lot.
offlineUSMT.xmlFetching info...
scanstate.logFetching info...
runscanstate-offlinewindirx64.txtFetching info...
There is a space between amd64 and the backslash. See in your scanstate.log: 2012-07-26 11:26:15, Info [0x000000] Startup exclusions - Adding excluded file pattern: C:\USMTbits\amd64 \* [*]
2012-07-26 11:26:15, Error [0x000000] EngineStartup caught exception: Win32Exception: c:\USMTbits\amd64 : The system cannot find the file specified. [0x00000002] class UnBCL::String *__cdecl UnBCL::Path::GetLongName(const class UnBCL::String *)[gle=0x00000002
hi ,
After migration data kept in USMT offline folder but loadstate failed ... i have checked to open a folder but it shows access denied ...... and also before migration xp\windows is in c: drive but after migration win 7\windows install in d: drive ...and also i am not found scanstate.log file..
loadstate.logFetching info...
Thank you Peter that got me past that part. Now it goes all the way through the Task Sequence but it fails on the restore part and doesn't give me enough time before it restarts the computer to see what the error is? I can still see the USMToffline folder on the C:\ any thoughts?
look for the loadstate.log file in this location, it's listed clearly in your smsts-.... log file (did you look at the contents of that log file?)
C:\Windows\SysWOW64\CCM\Logs\SMSTSLog\loadstate.log
post that loadstate.log file here and we'll help you.
