hi all,
  Quote
/offlinewindir: "path to a windows directory"
This option specifies the offline Windows directory that the ScanState command gathers user state from. The offline directory can be Windows.old when you run the ScanState command in Windows or a Windows directory when you run the ScanState command in Windows PE. This option is incompatible with the /offline option.
The theory behind this:-
Get your lab ready
The Task Sequence
Offline Mode in Windows PE using USMT 4.xmlFetching info...
SET
CREATE
and c:\USMTbits\X86
XCOPY
runscanstate-offlinewindir.bat.txtFetching info...
RUN
Testing Offline Mode.
browse it and verify
smsts.logFetching info...
Ok now what ?
Just wondering if anyone had an other suggestions to my issue:
"look for the loadstate.log file in this location, it's listed clearly in your smsts-.... log file (did you look at the contents of that log file?)
C:\Windows\SysWOW64\CCM\Logs\SMSTSLog\loadstate.log
post that loadstate.log file here and we'll help you."
When I go to C:\Windows\SysWOW64\CCM\Logs there is not another folder called SMSTSLog.
I even ran a search on the entire C: drive for loadstate.log and it didn't find it.
Just incase i messed up on the Task Sequence I have attached a copy of it.
  On 7/7/2010 at 6:06 PM, Skiddy said:
I saw this up before, thanks for the tip. Can this be used offline in PE though? I thought the Request, Capture, Release had to be done online
I have the same question...
Is it possible to do an Offline - In-place upgrade using SMP?
All i get are errors saying it cant find hte SMP..
Alternatively if i do it live on the machine...with 2012 you need to copy all packages refering to teh TS locally...essentially doubling the storage requirements.
Any help would be great. Cheers
I actually have a strange issue going on. I am using the XP to W7 Demo TS as my template for hardlink USMT however during the process the XCOPY command seems to be trying to copy the entire contents of my distribution point to the client. The command I am executing is as follows:
xcopy * %systemdrive%\USMTbits\X86 /herciy
I am also including a package that includes the x86 folder of the USMT folder in the "Run Command Line". What I was expecting to happen was that the contents of the package should be copied to the %systemdrive%\USMTbits\X86 folder, not the entire contents of my DP. The result is that the TS takes a huge amount of time and fills the drive of the client workstation. I am going to poke around and see if I can use a batch file to copy the USMT files and the runscanstate batchfile. If anyone has any ideas on how to fix my xcopy problem and to limit what xcopy is copying I would appreciate it.
I am getting a slight problem when i run the offline hardlink TS. When it runs my runscanstate.bat file, it comes up with a "Settings store argument specified is invalid 0x00000091. I have been at it for a while and i need a second, third, and maybe even fourth eye on this. I have included the TS (xml) and the runscanstate syntax (txt). Please tell me what i am missing. Im starting to see double.
runscanstate.txtFetching info...
USMT-HARDLINK-TEST(Offline).xmlFetching info...
I would say this is very impressive solution! Before I adopt it for my deployment, I'd like to know if I am able to achieve similar result by just adding an additional "Restart Computer" as the very first task in with my traditional MDT Task Sequence? I have no offend but seeking a simpler and safer solution.
Thanks a lot.
Hello
I am new in SCCM, so sorry about possible silly questions. I have
build up a base image (wim file) that has all the apps and basic
configurations. For the final deploy for my users i have a TS that apply
that base wim with a few other step, namely driver packages and a
registry change that redirects the folder “users” for the D: drive.
Everything works fine, Now what i need to do is to build a new TS for
refresh scenarios, following the above explanation everything seems to
work fines, except for the fact the my profiles are located on d:\users,
and when the TS finishes one of the two scenarios happens:
a) if i use the step to redirect the users profile do drive D:, when i
logon to the machine it creates a second profile in the D: drive. For
example if the user is John, a have a john profile (the old one
containing the real data) and a new one DOMAIN\john, which of course is
empty without the migrated data.
B) if i simply just disable this redirection step, when i logon it
creates a new profile named john in drive c:\users and it just ignores
the old profile in D:\users\john
I need to maintain the D:\users\john profile and that after the
refresh when the user logon it assumes the old profile. Can anyone help
me in this situation? what on hell am i doing wrong ….
Thanks on advanced :)
