hi all,
  Quote
/offlinewindir: "path to a windows directory"
This option specifies the offline Windows directory that the ScanState command gathers user state from. The offline directory can be Windows.old when you run the ScanState command in Windows or a Windows directory when you run the ScanState command in Windows PE. This option is incompatible with the /offline option.
The theory behind this:-
Get your lab ready
The Task Sequence
Offline Mode in Windows PE using USMT 4.xmlFetching info...
SET
CREATE
and c:\USMTbits\X86
XCOPY
runscanstate-offlinewindir.bat.txtFetching info...
RUN
Testing Offline Mode.
browse it and verify
smsts.logFetching info...
Ok now what ?
  On 8/27/2010 at 12:17 PM, agrau said:
I am in the same boat have you been able to edit the TS to make it work in MDT 2010 with hardlinks, offline and install OS then loadstate?
Yes I did !! Works perfect except it seems to miss some desktop icons. I think I need to create a Custom.xml file. You can use this task sequence as is, works quite well. I've attached my Task Sequence, you just need to fix the OS info and the servername(MDT).
ts.xmlFetching info...
  On 9/2/2010 at 7:46 PM, anyweb said:
good work Terry, and thanks for sharing, Offline mode in WinPE rocks doesn't it :)
can you give me a hand to find a solution for my problem? I posted 2 articles above.
Thanks in advance.
Rudi
Much thanks for this TS as USMT as been a pita for me -
Question:
I am at the Task "xcopy x86 USMT to USMTbits\x86"
pressed f8 to check folder status:
under c:\usmtbits\x86 I am seeing a bunch of packages being downloaded...
Did I do something wrong...
TS is still running/sitting at that point
check the distribution settings of your advertisement
see this post for details of what i'm talking about
http://www.windows-noob.com/forums/index.php?/topic/2758-how-can-i-copy-files-from-a-package
I have USMT offline working with SCCM 2007 R2 but I have a problem if I do not delete the computer from Active Directory before the build. I am using the Unknown Computers collection to assign the Computer Name during the Task Sequence. The OS build works correctly when I delete the compueter name from AD before the build. If I do not remove the computer account the process assigns a MININT-xxxxx and joins that name to the domain. What can I do to fix this issue.
Thanks.
