xstnc Posted February 19, 2010 Report post Posted February 19, 2010 Hi, I've set up an environment which in the future is going to deploy win7 to several computers. When going trough various guides and similar, I can't find any way to make the HP 3D Drive guard driver and the driver for Quicklaunch install. Does any of you have it working? Incase, how? At the moment it's setup as a software package (one per driver/software). Could anyone point me in the right direction? Thanks! Quote Share this post Link to post Share on other sites More sharing options...
0 xstnc Posted February 19, 2010 Report post Posted February 19, 2010 Solved the Quicklaunch problem by adding this: setup.exe -s /f2c:\setup.log /V/qn Still having an issue with 3D Driveguard Quote Share this post Link to post Share on other sites More sharing options...
0 anyweb Posted February 21, 2010 Report post Posted February 21, 2010 what does the 3d drive guard software do and what problem are you having with it exactly ? Quote Share this post Link to post Share on other sites More sharing options...
0 xstnc Posted February 21, 2010 Report post Posted February 21, 2010 Supposedly protects your hdd when in movement. It's a driver/software issue.. I've tried adding all drivers in respective folders (.ini files) and added the rest that HP computers require (such as Quicklaunchbuttons ect.) as a software installation. When the test-machine boots up after a successfull win7 installation, the DriveGuard is the only thing still showing with a yellow ! in the device manager. (not successfull installing the software/driver). I've tried launching the setup from within a .bat, and that won't work. I've tried it as a software package (which I had to do with the rest in the same category) I just don't know how to solve it! Quote Share this post Link to post Share on other sites More sharing options...
0 anyweb Posted February 21, 2010 Report post Posted February 21, 2010 can you please give me a download link for this software and i'll take a look, unfortunately i don't have a HP laptop but i'd still like to take a look Quote Share this post Link to post Share on other sites More sharing options...
0 xstnc Posted February 22, 2010 Report post Posted February 22, 2010 Here is a link! 3D DriveGuard Thanks a million! Still got me puzzled.. And anything you can think of would be worth trying! Quote Share this post Link to post Share on other sites More sharing options...
0 Basun101 Posted April 15, 2010 Report post Posted April 15, 2010 Well hello there, Is there somebody who worked it out?? We did have the same problem and we placed it in the tasksequence just before a reboot and it worked greetz Bas Quote Share this post Link to post Share on other sites More sharing options...
0 jeaostro Posted April 27, 2010 Report post Posted April 27, 2010 On 2/21/2010 at 4:26 PM, xstnc said: Supposedly protects your hdd when in movement. It's a driver/software issue.. I've tried adding all drivers in respective folders (.ini files) and added the rest that HP computers require (such as Quicklaunchbuttons ect.) as a software installation. When the test-machine boots up after a successfull win7 installation, the DriveGuard is the only thing still showing with a yellow ! in the device manager. (not successfull installing the software/driver). I've tried launching the setup from within a .bat, and that won't work. I've tried it as a software package (which I had to do with the rest in the same category) I just don't know how to solve it! Hello Have you tried to copy the application to the computer and running it from the computer(in the os deployment task)? Had similar problems with some Lenovo Applications that are both a driver and an application. One cmd step in the task for copying the application to the client(cmd step with Xcopy -parameters \\server\xxx\"packet id"\ c:\drivers\xxx then a new cmd step for launching the installation on the client("in the "start in" type c:\drivers\xxx") and then as the command line type something like setup.exe -s A workaround that worked for me Quote Share this post Link to post Share on other sites More sharing options...
Thanks!
