wmmayms
Simple report for counting IE versions
Here you go:
SELECT ExecutableName0, ProductVersion0, count(*)
FROM
v_GS_INSTALLED_EXECUTABLE
WHERE ExecutableName0 = 'iexplore.exe'
GROUP BY ExecutableName0, ProductVersion0
Order by ExecutableName0
Example:
  On 3/8/2010 at 2:26 PM, anyweb said:
great stuff :)
and if we wanted to have two reports for counting IE6 and IE8 ?
I don´t understand how you mean.
Do you want a report that combines all versions so you only see version 6 and version 8?
  On 3/9/2010 at 8:45 AM, anyweb said:
ok lets just say we want one to count all versions of ie8
should be easy enough to do or ?
Yes :)
just add the part in red:
FROM
WHERE ExecutableName0 = 'iexplore.exe' and ProductVersion0 LIKE '8%'
To make it count all instances of just IE 6 just change the '8%' to '6%'
  On 9/19/2010 at 9:20 AM, flyingbirds said:
Am in new in reporting & SCCM , I tried to create a new report and add this to SQL statement but there is result when running the report.
may be I forgot something I don't know?
the question is to be no Result isn't it ? Do you see any error or blank web page ? check if you have software inventory enabled for .exe?
  On 9/21/2010 at 6:56 AM, YiannosG said:
Hello.
No matching records could be found.
And i have the software inventory on
Thank you
Do you have Asset intelliegence enabled in your site since v_GS_INSTALLED_EXECUTABLE View Lists information about the installed software application executables on Configuration Manager clients found through Asset Intelligence.
To get the list of Iexplore versions,use this syntax:
 select filename as "executable name",left(FileVersion,14)as "File Version",COUNT(*)as Total from v_GS_SoftwareFile where FileName='iexplore.exe'
group by FileName,FileVersion
More on Iexplore here
Thx for clearing it out :)
