yusukejan
WDS setting question
Hi~all
Some WDS setting question need your help
1.On WDS\action\properties\boot setion
Deafule boot program
x86/x64 architecture
i need to change boot image path
or
keep defult?
2.after PXE boot
get error message as
Boot\BCD
Ox00000098
the windows boot configuration data file not contain a vild OS entey.
3.I try to add boot image to WDS,image form \SCCM\OSD\Boot\X64\boot.jww00070.wim(i had set a custom background)
it work ,system can be boot to winPE(custom background show).but can't install OS.
sorry for my poor english skill
and THX
2 answers to this question
you dont need to configure WDS,
is dhcp server and wds on the same machine ? or different ? is sccm on the same server as wds ?
HI anyweb~thank you
yes, my DHCP/WDS/SCCM on same server.
a other question
What IS right WDS DEFAULT boot setting value???
setting x86/x64 both to pexboot.n12 or WDSNBP.com?
i try to setting WDS BOOT x86/x64 both to
WDSNBP.com
boot clinet to PXE boot, display loop message as below
"TFTP download boot\x64\wdsnbp.com
downloaded wdsnbp"
If setting to Pxeboot.n12 get message as below
Boot\BCD
Ox00000098
how can i fix this issue?
