This is my first attempt at OSD with SCCM, so forgive me if this is a noob issue. I have several drivers set to apply in my TS, and they seem to install without issue. The problem is I have to go into Device Manager after the TS has run and run a manual "Update Driver" for Plug and Play to properly install them. Scanning for hardware changes has no effect.
The Apply Device Driver portion of the TS has the following settings:
1) Install all drivers as well as Install only the best matched have both been tried
2) Unattended install of unsigned drivers is enabled, as well limited by category
3) WMI query in the options to target the specific model
The only errors/warnings I've found in the smsts.log file are related to Health Validation, which we aren't using and some registry key deletes during the TS cleanup.
