kfv7
Problem with custom report
Hi, I am new to this forum. I have a problem, i have to make a report in SCCM 2007 and I dont know SQL. I have made the following one copying from others ones.
declare @Total int
declare @Succeeded int
declare @Failed int
declare @InProgress int
select @Succeeded = count (*) from v_ClientDeploymentState where DeploymentEndTime is not NULL
select @Failed = count(*) from v_ClientDeploymentState where LastMessageStateID>100 AND LastMessageStateID<400
select @InProgress= count(*) from v_ClientDeploymentState where DeploymentEndTime is NULL and LastMessageStateID = 100
select @Total = @Failed + @InProgress + @Succeeded
if @Total > 0
begin
select @Total as ComputersWithStatus, @Succeeded as DeploySucceeded, @Failed as DeployFailed, @InProgress as DeployInProgress, round(100.0*@Succeeded/@Total,2) as SuccessRate, round(100.0*@Failed/@Total,2) as FailureRate, round(100.0*@InProgress/@Total,2) as InProgressRate
end
select FQDN as MachineNameFQDN, NetBiosName as MachineNameNetBios, ClientVersion as ClientVersion, DeploymentBeginTime as DeployStartTime, StateDescription as InProgressDescription, LastMessageParam as DescriptionParam from v_ClientDeploymentState where DeploymentEndTime is NULL and LastMessageStateID = 100
select FQDN as MachineNameFQDN, NetBiosName as MachineNameNetBios, ClientVersion as ClientVersion, DeploymentBeginTime as DeployStartTime, StateDescription as FailureDescription, LastMessageParam as DescriptionParam from v_ClientDeploymentState where LastMessageStateID>100 AND LastMessageStateID<400
select FQDN as MachineNameFQDN, NetBiosName as MachineNameNetBios, ClientVersion as ClientVersion, DeploymentBeginTime as DeployStartTime, DeploymentEndTime as DeployEndTime, RebootNeeded as RebootNeeded from v_ClientDeploymentState where DeploymentEndTime is not NULL
The report shows the status of the SCCM client installation. I have to add a column to the 3 tables that shows the status of each pc. The column have to show the Description of the computer in Active Directory. I try adding the line "select SMS_R_System.description0 as Description", but I get the error "The multi-part identifier "SMS_R_System.description0" could not be bound".
Any help would be greatly apreciated.
Sorry for my poor english
0 answers to this question
