Jepeto 46
Customize wallpaper and lockscreen
Building the reference  Image with MDT
Looking to permanently customize corp wallpaper and lock screen in the reference image.
I found a lot of scripts and methods to do so, however I was hoping that using the MDT $OEM$ folder will do the trick for me but it does not. Any advice on the topic?
My $OEM$ folder is set this way:
\$OEM$\$1\Windows\web\4K\Wallpaper\Windows
all images replace with my company's as well as the Img0
