steve_nrw Posted April 23, 2010 Report post Posted April 23, 2010 Hello Guys! I've got a problem. I created a Software Package (Office 2007) and a Program. Both are shown in Packages. If i try to add the package in my Task Sequence i see the Package but not the Program, so i cant save the TS. I hope you can help me. Thanks! steve_nrw Quote Share this post Link to post Share on other sites More sharing options...
0 tiandu Posted April 23, 2010 Report post Posted April 23, 2010 On 4/23/2010 at 11:23 AM, steve_nrw said: Hello Guys! I've got a problem. I created a Software Package (Office 2007) and a Program. Both are shown in Packages. If i try to add the package in my Task Sequence i see the Package but not the Program, so i cant save the TS. I hope you can help me. Thanks! steve_nrw Hi, I had this problem when I had set "Allow users to interact with this program" on the Install procedure. You should find that setting on the "Environment" tab. Tim Quote Share this post Link to post Share on other sites More sharing options...
0 anyweb Posted April 23, 2010 Report post Posted April 23, 2010 and make sure that 'allow this program to be run whether or not it is advertised' is selected, the task sequence will need that step removed, then yuo can save the ts, then edit the ts again to re-add the corrected package, unfortunately it doesn't refresh on the fly Quote Share this post Link to post Share on other sites More sharing options...
0 steve_nrw Posted April 23, 2010 Report post Posted April 23, 2010 Thank you guys for the fast reply! I thought it was a mixture of both :) Now i can see the Program. Big THX! Quote Share this post Link to post Share on other sites More sharing options...
0 steve_nrw Posted April 26, 2010 Report post Posted April 26, 2010 Another problem.... I Configured the Office Package like in MS TechNet (http://technet.microsoft.com/de-de/library/dd630737.aspx) In the TaskSequence you can see that he Install the Package. After the TS, there is no Microsoft Office installed. Any ideas? Thanks! steve_nrw Quote Share this post Link to post Share on other sites More sharing options...
0 anyweb Posted April 27, 2010 Report post Posted April 27, 2010 try http://www.windows-noob.com/forums/index.php?/topic/968-how-can-i-deploy-office-2007-with-sccm/ if you cannot get it to work then post your smsts.log file here Quote Share this post Link to post Share on other sites More sharing options...
Hello Guys!
I've got a problem.
steve_nrw
