We have 1 primary site with 8 secondary sites. Between them more than 20km so it's over WAN but not through the internet, it's going through the same lan over wan connection.
Bandwidth is more than 10Mbit/s.
Every secondary site has it's own domain name because it's each time another client. All clients do have the same site code that is the one from the primary site server (ours).
They are all using SCCM 2007 SP1 R2 and waiting for SP2 but due to complications with this problem I cannot do it.
We can install perfectly a machine using the task sequences but when I secondary site wants to do the same it doesn't find it's boot package. It finds the secondary site but it cannot boot.
BUT when, in the advertisement, I check the option 'When no local distribution point is available, use a remote distribution point' it will work but it's slower.
So which sites are protected here: all of my secondary sites but not the primary site.
MORE I have a client who has 2 locations and on each location he has a secondary site because he must install machines on both sites. I've put the correct ip subnet as boundary on 1 site and 1 on the other and also protected. Site A has ip subnet 10.75.4.0 (workstations) and is protected but the server is in subnet 10.75.7.0 and isn't in the boundary, could this be the problem or doesn't the ip subnet not be in the boundaries?
Where to begin...
I am getting nuts
:angry:
