WoeKz
Sysprep dosent work.
2020-02-12 18:16:46, Info                  SYSPRP ========================================================
2020-02-12 18:16:46, Info                  SYSPRP ===          Beginning of a new sysprep run          ===
2020-02-12 18:16:46, Info       [0x0f004d] SYSPRP The time is now 2020-02-12 18:16:46
2020-02-12 18:16:46, Info       [0x0f004e] SYSPRP Initialized SysPrep log at C:\WINDOWS\system32\sysprep\Panther
2020-02-12 18:16:46, Info       [0x0f0054] SYSPRP ValidatePrivileges:User has required privileges to sysprep machine
2020-02-12 18:16:46, Info       [0x0f007e] SYSPRP FCreateTagFile:Tag file C:\WINDOWS\system32\sysprep\Sysprep_succeeded.tag does not already exist, no need to delete anything
2020-02-12 18:16:46, Warning               SYSPRP WinMain: File operations pending
2020-02-12 18:16:46, Info       [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'GENERALIZE'
2020-02-12 18:16:46, Info       [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'SHUTDOWN'
2020-02-12 18:16:46, Info       [0x0f003d] SYSPRP WinMain:Displaying dialog box for user to choose sysprep mode...
2020-02-12 18:16:48, Info       [0x0f00d7] SYSPRP WinMain:Pre-validing 'cleanup' internal providers.
2020-02-12 18:16:48, Info                  SYSPRP RunDlls:Running platform actions specified in action file for phase 3
2020-02-12 18:16:48, Info                  SYSPRP SysprepSession::CreateSession: Successfully created instance with action file C:\Windows\System32\Sysprep\ActionFiles\Cleanup.xml, and mode <null>
2020-02-12 18:16:48, Info                  SYSPRP SysprepSession::Validate: Beginning action execution from C:\Windows\System32\Sysprep\ActionFiles\Cleanup.xml
2020-02-12 18:16:48, Info                  SYSPRP SysprepSession::CreateXPathForSelection: Sysprep mode in registry is <null>
2020-02-12 18:16:48, Info                  SYSPRP SysprepSession::CreateXPathForSelection: Processor architecture in registry is AMD64
2020-02-12 18:16:48, Info                  SYSPRP ActionPlatform::LaunchModule: Executing method 'Sysprep_Clean_Validate_Opk' from C:\Windows\System32\spopk.dll
2020-02-12 18:16:48, Info                  CSI    00000001 Shim considered [l:125]'\??\C:\WINDOWS\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.18362.651_none_5f2896f458eff373\wcp.dll' : got STATUS_OBJECT_PATH_NOT_FOUND
2020-02-12 18:16:48, Info                  CSI    00000002 Shim considered [l:122]'\??\C:\WINDOWS\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.18362.651_none_5f2896f458eff373\wcp.dll' : got STATUS_SUCCESS
2020-02-12 18:16:48, Error                 SYSPRP Sysprep_Clean_Validate_Opk: Audit mode can't be turned on if there is an active scenario.; hr = 0x800F0975
2020-02-12 18:16:48, Error                 SYSPRP ActionPlatform::LaunchModule: Failure occurred while executing 'Sysprep_Clean_Validate_Opk' from C:\Windows\System32\spopk.dll; dwRet = 0x975
2020-02-12 18:16:48, Error                 SYSPRP SysprepSession::Validate: Error in validating actions from C:\Windows\System32\Sysprep\ActionFiles\Cleanup.xml; dwRet = 0x975
2020-02-12 18:16:48, Error                 SYSPRP RunPlatformActions:Failed while validating Sysprep session actions; dwRet = 0x975
2020-02-12 18:16:48, Error      [0x0f0070] SYSPRP RunDlls:An error occurred while running registry sysprep DLLs, halting sysprep execution. dwRet = 0x975
2020-02-12 18:16:48, Error      [0x0f00d8] SYSPRP WinMain:Hit failure while pre-validate sysprep cleanup internal providers; hr = 0x80070975
2020-02-12 18:16:48, Info       [0x0f0052] SYSPRP Shutting down SysPrep log
2020-02-12 18:16:48, Info       [0x0f004d] SYSPRP The time is now 2020-02-12 18:16:48
Edited by WoeKz
I posted the long version
