ADB Posted May 18, 2010 Report post Posted May 18, 2010 Hi everyone My Client starts the TS and when trying to load NW-Drivers it is interrupted! My Log File sais: - Failed to get Client Identity ....HRESULT: 80072ee7 - sending with winhttp failed...failed to send the request - ClibSMSMessageWinHttpTransport::Send: URL: SCCM-TEST.SERVICE.TEST:80....Error. Received 0x80072ee7 from WinHttpSendRequest... When I open the command prompt on the client and type ipconfig /all there's a strange DNS IP Address (looks like IPv6) has anyone had a similar issue? My drivers should be the right ones and are updated on DPs. But anyways, it doesn't look like a Driver-problem... My DNS Server and the DHCP Server haven't got the same names...should it be??? Any ideas? Quote Share this post Link to post Share on other sites More sharing options...
0 ADB Posted May 18, 2010 Report post Posted May 18, 2010 By the way. This is about a deploy 7 TS, not a capture or build... The Target Computer is a baremetal, so I can't configure DNS in Network Adapter Settings. Where else do I configure DNS in a TS or Unattend.xml besides the Domain Joining in the TS? has anyone got an idea? Thanks a lot, I'm struggling with this since months... Quote Share this post Link to post Share on other sites More sharing options...
0 anyweb Posted May 18, 2010 Report post Posted May 18, 2010 sounds more like you don't have an ip address instead of missing dns info, without an ip you can't do anything else, so.... are you using an apply drivers step before this happens ? have you added network card support for this computer to the boot image ? Quote Share this post Link to post Share on other sites More sharing options...
0 ADB Posted May 19, 2010 Report post Posted May 19, 2010 On 5/18/2010 at 3:13 PM, anyweb said: have you added network card support for this computer to the boot image ? I will add an auto apply drivers step after restert in WinPE. I've allready added several nw drivers to the boot image, though. probably it was the drivers.. but isn't it enough to only add them to the boot image??? Will try to figure it out Quote Share this post Link to post Share on other sites More sharing options...
0 ADB Posted May 19, 2010 Report post Posted May 19, 2010 All my Computers are interrupted the same way! Error. REceivved 0x80072ee7!!! getHostByName Failed... In the Beginning the Computer gets an IP Address. Do I have to add an Add Driver Package before the Auto Apply Drivers? Does the autoapply happen before the "restart in Windows PE" Step of the TS? The Drivers are now well akknowledged in the Boot Image What am I doing wrong? Quote Share this post Link to post Share on other sites More sharing options...
0 ADB Posted May 20, 2010 Report post Posted May 20, 2010 Well I 've added the Option 005 and 006 in my DHCP Scope, checked the Network Access Account in Client Agents, checked if Spanning Tree is enabled on the Switch, Traced with Wire Shark and finally got one step futrher. It is now loading the Drivers from the Auto Apply Drivers Step from the TS IN ADDITION WITH THE TASK SEQUENCE ERROR WINDOW saying: Task Sequence: ... failed with error code 0x80004005. ...please contat system administrator! and smsts.log failes with GetHostByName with error code: 0x80072ee7 ipconfig has now the right IP Address of the DNS Server When removing the Auto Apply Driver Step from the TS it is interrupted as allready mentioned above. smsts.log is still saying, that it failes with GetHostByName with error code: 0x80072ee7 isn't it enough to have got the nw-drivers mounted in the boot image? thanks anna Quote Share this post Link to post Share on other sites More sharing options...
0 anyweb Posted May 20, 2010 Report post Posted May 20, 2010 first of all one step at a time during the deployment before it fails if you bring up a command prompt, can you get an ip address ? does it look correct ? if so, can you ping the FQDN of your sccm server ? in the same LAB does nslookup on a workstation report back the correct details for DNS ? Quote Share this post Link to post Share on other sites More sharing options...
0 ADB Posted May 20, 2010 Report post Posted May 20, 2010 On 5/20/2010 at 9:07 AM, anyweb said: first of all one step at a time during the deployment before it fails if you bring up a command prompt, can you get an ip address ? does it look correct ? if so, can you ping the FQDN of your sccm server ? in the same LAB does nslookup on a workstation report back the correct details for DNS ? I Got it solved, removed the Auto Apply Drivers and re-checked the Scope Options. I got an IP Address, nslookup wasn't supported as a command... My Client is continuing with Formatting, installing the Capture.wim to the right partition, Applies NW- and Device Settings and Sets up the windows and ConfigMgr. it reboots several times in between. After having installed devices and applying system settings, it fails durich checking of video performance: "Windows could nit parse or process unattend answer file [C:\Windows\Panther\Unattend\unattend.xml]" for pass [oobeSystem]... while processing settings for component [Microsoft-Windows-Shell-Setup]." I checked the .xml and saw, that I had forgotten to correctly write %SYSTEMDRIVE%\Program Files in the Program Data of UserDirectory. After having changed it, still the same error message with same source. My .xml is not in the ...Panther... Folder! shall I move my .xml to there and change its name? Sorry. Shall I start a new topic? thanks niall Quote Share this post Link to post Share on other sites More sharing options...
Hi everyone
My Log File sais:
Any ideas?
