SHASHIDUBEY01
Domain Join issue During OSD
Hi everyone,
Hope everyone is doing great and being safe!
Need your expertise with an issue I am facing during domain join during OSD where clients are failing to join to the domain during OSD.
Upon checking the netsetup log we found the below error:
NetpValidateName: checking to see if 'XYZ.global.corp' is valid as type 3 name
10/07/2020 16:09:48:459 NetpValidateName: 'XYZ.global.corp' is not a valid NetBIOS domain name: 0x7b
10/07/2020 16:09:48:459 NetpCheckDomainNameIsValid for XYZ.global.corp returned 0x54b, last error is 0x0
10/07/2020 16:09:48:459 NetpCheckDomainNameIsValid [ Exists ] for 'XYZ.global.corp' returned 0x54b
10/07/2020 16:09:48:459 NetpJoinDomainOnDs: Domain name is invalid, NetpValidateName returned: 0x54b
10/07/2020 16:09:48:459 NetpJoinDomainOnDs: Function exits with status of: 0x54b
10/07/2020 16:09:48:459 NetpJoinDomainOnDs: NetpResetIDNEncoding
A surprise to our beliefs when we use the same Account and password and try to join the domain manually it was successful and it worked. Other logs such as Setuperr are not created and we have the above error only documented multiple times as a final error too.
If someone faced this issue kindly reply so your's experience and expertise could prove to be helpful for me to fix this issue.
Regards,
Shashi Dubey
