MRaybone
Build & Capture Win7, Capture Fails to Start...
Hi All,
After running through the Deploy Vista guides, I've started through the Win7 guides to build and capture an image. I've run into a weird little problem where the system builds Win7 fine and installs the specified packages, configures the client etc. but instead of rebooting and completing the image capture, the system just displays a blank screen. On a hard reset it boots into Win7 as if it were the first time since install and the process is over. I checked out the SMSTS.LOG but it looks clean and I can't spot where the capture failed to start or why. Any ideas?
Cheers,
MRaybone.
Ok, on my 3rd attempt, I kicked off the Task Sequence and then went on a very extended lunch break to leave the laptop to its own devices. When I got back it was capturing the image, looks like I just have to sit and wait out the mysterious blank screen.
