Pulling my hair out folks. I have created Boot images and injected drivers for the Intel 82567LM-3 used in the Dell Latitude E6410. I can PXE boot just fine and successfully run a task to put Windows 7 on the laptop.
I created a Capture Image CD to capture the image but it fails. Looking through the smsts.log the first error I see is that a network card could not be found, other errors tell it could not connect to the share where I'm placing my captured image (because no network card).
When I created the Image Capture Media, I specified the same exact boot image I use in my Task Sequence to put Windows 7 on the laptop (which works fine).
Anyone else have this problem. I am really beginning to dislike the Dell Latitude E6410.
