I've been having some problems with the 974571 hotfix (KB977203). It installed on the server but it fails to install on the clients.
My solution was to try and send a task sequence to the client that first runs a command line command that uninstalls the 974571 update but represses the reboot, next step, the TS reboots the machine back into installed operating system. However, after the reboot, the task sequence does not continue and does not capture state. I had to create another TS with request, capture and release and that successfully captures the state after the reboot.
I would love to get the hotfix installed but it fails on all clients. Second, I'd like to know if there is a way to get the tasksequence to restart the machine and then continue from the next step.
Any one have a solution for this?
